Moog vs Mevotech?
I’m happy with the Moog Problem Solver ball joints on a friend’s Explorer. But many won’t grease them. Moog was reboxing 555 Sankei or Central for Japanese/Korean tie rods, ball joints or sway bar links. Dunno if they still are.
Also, I prefer to buy these local or at Rock. Amazon and eBay harbor fakes but the former is now being Driv’s (Carl Icahn) preferred distribution means now that Pep Boys doesn’t exist as a parts store outside of Philly(they still do service outside of there but many of them are located within an Advance) and the bigger chains want to push their reboxes of Mevotech(MasterPro Chassis, Duralast and WearEver).
I wish I could get a 555 rebox. The Moog directions say to grease every 2000-4000 miles which is ridiculous. This isn't 1960. No one is going to crawl under their car every 2k miles to grease them.
So... OE sucks. Moog sucks. Mevotech sucks. Cheap chinese crap, obviously, sucks. What is one to use?!?
20k on my 2011 F150 Moog front end "rebuild" (tie rods, upper control arms, lower ball joints) and its still tight and happy. 100k+ on OEM.
I don't think I've ever seen anyone prefer aftermarket over OEM until that guy. It's pretty much common "knowledge" (ok I'll use quotes) that OEM is the only assumingly reliable choice. Not to say all OEM is good. I mean if you're buying Kia and Scion parts... maybe make them yourself. 😁
Bit late to this, but important update. Since installing the Bilstein B6 struts on the van I wanted a heavy duty end link also. So the shop and I purchase the Moog, Mevotech and Duralast heavy duty end links for the 2020 Connect. Over the weekend, we drove with these end links to see if they suited the van. The end result, all three of these end links damaged the van's inner fire wall/chases/frame. Deep gashes on the frame and at one point at one of the end links got lodged between the coil springs and firewall/frame. We sent word to all three manufactures and only Duralast removed these links as being suitable for the Connect. Mevotech and Moog have yet to comment or remove these links from the vehicle drop down. Duralast was disappointed in hearing that their end links would not articulate correctly on the van and sent us another set of cheaper end links. While posting this several months ago, an Amazon vendor claiming to be with Zeder Corp ask if they could help with the van build. They sent us a set of their Super-pro 300mm-345mm Volvo end links. We've yet to adjust these because we're still searching for a performance sway bar for the van. Moral of the story, if you purchase something from a site that lists it for your vehicle and it doesn't actually fit, contact the part manufacture and let them know as well as send pictures.. because to them.. it looks good on paper, yet no one has actually fitted these products on their vehicles until it's too late.
Deep gashes on the inner firewall/frame right beside the B6 strut
I need to revisit this in a few months - the Ranger is due for a front end rebuild. I’m leaning towards Motorcraft LBJs, Moog LCA bushings and Delphi UCAs. Motorcraft still stocks the inner tie rods but not the outers.
Not using Moog Problem Solver grade or anything Mevotech. Also staying with sealed.
stick with Motorcraft, CTR, Delphi, and Sankei 555
Get the Motorcraft upper and lower control arms. They have the ball joints already installed. All four are still available from Rock Auto :)
Motorcraft inner and outer tie rods are also listed on RA for your 1998 Ranger
Motorcraft only has those for 4x4 torsion bar models. This is a 4x2 coil spring model.
Do a little checking, including factory part numbers, i sourced all of mine for a 2002 form Motorcraft all be it a few years ago. Energy Suspension for sway bar bushings and end links. IRRC the Motorcraft had "oe" after the part number. I did the lower ball joints and upper arms.
Looking for some discussion on some of the commonly available aftermarket replacement parts out there, specifically the Moog CK series (aka Problem Solver) vs the Mevotech TTX line. Is either a worthy replacement for OE when needed? Is either actually better than the other? If you have to have context, lets say on either of my F150's which I plan to run indefinitely at this time. About 2-3x per year they see fire trail and two track but nothing hardcore or really offroad.
Mevotech TTX line is great.
Anyone got experience with Dorman premium control arms? Supposed to be better than Dorman OE solutions control arms?
Trying to see if there’s any difference between these two, they look identical except the premium one seems to have been a more recently released item.
Dorman CA96033PR vs. Dorman 524-904
Price is only like $20 different too. Strange.
Would Dorman Premium (not Dorman OE) or Suspensia be on the same level as Delphi or CTR?
From what I am seeing my 96 Grand Marquis have plastic tie rod balls in them. Moog and Mevotech have sintered powder metal which has to be better than plastic if you keep them lubed. The OE are sealed non greasable and I prefer being able to put my own grease in it.
I have a 2010 ford f150. I have replaced both upper control arms arount 65000 miles with moog. I had to replace them again at 135000 miles. so to me they are the same as ford. I replace the front struts at 105000 miles because the spring broke in the middle. they are still working fine but the spring rate has always been too firm. I replaced the ball joints at various times but around 125000 130000 on both and they are fine. I replaced an inner tie rod at 128000 miles on this vehicle. I say its as good as ford
The inner on a subaru outback 6 years ago and its still fine. Time will tell.
Moog has always been better than Mopar as least for me, using many to replace low mile Mopar steering parts. That being said, OEM is Almost always the best choice on Euro vehicles as they are normally 100000 mile plus parts. High end name brands NTN Koni, Koyo, SKF,Bando, Mitsuboshi Denso, and others. It really does depent on the brand as to how long things last. Aftermarket use to be good. I will not buy Timkin Gates. GMB Cloyes or no name aftermarket. I have been burned bad wasting coutless hours redoing jobs. Also, many other aftermarket parts unless... they are: easy to replace and they have a "REAL" lifetime warranty, Remanufactured is a crap shoot.
The key takeaway is this and its simple. If you purchase a vehicle and the oem part last 100000 miles and you want to forget about it for another 100000 miles get OEM. If your OEM part last 40000 to 60000 miles forget OEM and get a aftermarket part of good quality as it will last the same and this is what I have found in the last 50 years.
I think for mevotech is important to distinguish their generic Chinesium line vs the gold colored ttx stuff.
My moog stuff? Still not sure if dog crap or counterfeit.
