Molyslip 2001E
Europe
Has anyone used Molyslip 2001E and had good results? Would this just be pretty much the same as LM Mos2.It is apparently 0.5 micron size Mos2 and will not clog filters.Thinking it might be a good anti wear additive to use in any old,pre 1990 engine,or are these Mos2 additives really just snake oil?
http://www.molyslip.co.uk/products.php?cat=50
I wouldn't say snake oil as Moly is a good additive in a well balanced oil. If you want moly look thru the VOA and UOA section and pick an oil with higher Moly. Remember that a well balanced oil is a well engineered blend of many additives.
