Mobilube 75w-90 SHC
ant
Louisiana
I purchased a 5-gallon pail of Mobilube 75w-90 SHC today, and the label has Mobilube 75w-90 SHC printed with the description "Synthetic Gear Lubricant" on the left hand side. However, on the right hand side of the same label, there is another column that is titled "Item Description". At this location, under item description, the label has PETROLEUM OIL (HYDROCARBON LUBRICANT). Is this product a synthetic and conventional based?
Thanks!
I wanted to use this in a rear differential without a limited slip unit, but the manufacturer requires a synthetic gear lube. But, now I'm not sure if this is a synthetic.
I asked my local commercial Mobil distributer and he claims this tiny type is the way Mobil classifies ALL their lubes for inventory purposes.
Yes, it's full synthetic.
I doubt it would meet the Eaton Dana approval list for their 750,000 mile extended warranty with 500,000 mile drain interval if it wasn't a beefy synthetic.
The spec sheet also gives it away. Notice the low temp and high temp performance, no conventional gear lube could cover such a wide temp range.
I rest well at night running this product in my expensive Eaton Dana HP-40 tandems. It really is a good product, though unknown outside commercial trucking, industrial, and mining circles.
I've posted previous responses warning not to use it in any limited slip application, so you've paid attention. SHC would work fine in a mechanical "locker" though: example PowerTrax NoSlip and LockRite, Detroit Locker, etc.
If you require GL-4 lubes, you can get Mobil MobilTrans SHC 50. It's a companion product designed for all GL-4 stickshift transmissions, from light duty to HD truck. I run this in my HD trucks and have used it in my personal stickshifts that required a GL-4 lube: excellent results.
Jerry
Hi,
I have two trucks on 75w-90 SHC with about 600k covered and SHC50 in the gearbox.
No fluid changes in this time and I will post a used oil analysis on both in the next few weeks
Regards
