- Joined
- Nov 30, 2024
- Messages
- 1
Hello, I have a craftsman snowblower with a faulty drive system which I've acquired from my brother. After tearing it apart I've found that it has a sealed (ie non serviceable) transmission (Murray P/N 1733972YP) for the drive system. The entire transmission is made of plastic. I could purchase a replacement here https://www.partstree.com/parts/murray-1733972yp/ for $535.99 USD plus another $50 USD to ship to Canada! Not likely! I figured since it's not working and I'm not paying half the original price of the machine for a replacement part, I might as well tear it apart and check it out. The two halves of the case are sealed together with some kind of silicone gasket material so it was a pain to split apart. When it finally came apart a quantity of oil poured out. I drained the rest and separated the to halves. Also found this video which helped . This guy had bad bearing in his and replaced them fixing his problem. Mine however had worn clutch cones, I was able to shim the cones and get it working again. However unlike the guy in the video I did not save the fluid to reuse. So the question is what kind of fluid do I use in a transmission with a plastic case and plastic gears. The fluid that came out of it was not very thick, as you can see at about the 2:20 mark in the above linked video. I'm worried a regular gear oil will be too thick in -30°C conditions also the additives will probable kill the plastic gears. I've found this online: "Lubricants based on silicone, perfluorinated PFAE, mineral oils, and synthetic hydrocarbons (SHC or PAO), typically work well with plastics. Esters and polyglycols are generally not compatible with plastic, although there are exceptions based on the type of plastic material." Can anyone suggest a fluid that will work for this application?
Thanks,
Sam
Thanks,
Sam
