Mobil Oil 120926
What makes these two oils different ?​
Mobil 1 Extended Performance Full Synthetic Motor Oil 0W-20​
Mobil 1 Extended Performance 12096 Full Synthetic Motor Oil 0W-20​
Google is your friend. Learn to use it, learn to embrace it, learn to love it.
The number designates the packaging method. ***96 is, I believe, quarts and ***93 is for 5-quart jugs. I may have the numbers a bit off, but the numbers do indicate the type of packaging. The oil is the same. If you don't see a number like this in the description, it's only because it wasn't printed in the ad or description of the product, not because the item doesn't have a number or that it's a different product.
OP didn't provide enough info. There is nothing to explain. Some stores include a PN, and others don't.
I'm guessing that the newer might be the 'Triple Action' and maybe the store differentiates older jugs still in stock.
I myself am waiting for Mobil 1 QuintupleSynthetic or OctupleAction.
ExxonMobil gives different mile guarantees for those two products.
And you're contemplating buying one from Summit Racing? I could find vast pricing differences if I did that too.
Purchased today at Walmart for my 2020 GMC 6.2 Sierra . I just wanted to find out the difference in the oils and the cost. Just gonna stick with oil listed below. Thanks for all the replies.
You related to Atikovi. :D
