Mobil Annual Protection good for 2 years?
So. Cal.
Gents,
I have a 2015 Chevy Volt. This car has an engine and a large battery. Runs as a full electric until the battery goes flat. Then, it fires up the engine and operates very much like a Prius.
About 80%-90% of the miles are all electric, so the engine (and the oil contained therein) is hardly used. When it is, it's because we were on a road trip, so the engine warms up fully and burns off any condensate.
GM calls out Dexos 1. Mobil 1 Annual Protection meets Dexos 1. GM's Oil Life Monitor tracks both engine use, and calendar time. It will not let the oil go for more than 2 years in the sump.
GM says that any Dexos 1 oil can last up to 2 years, depending on engine use. Mobil says that their Annual Protection oil must be changed out after 1 year, no matter what the engine use.
Who's right?
Mobil would love to sell you oil every year. Seems like there was a discussion similar to this a while back. Two years is not a bad idea.
I would trust GM on this and follow the OLM, up to 2 years depending on usage, with any Dexos1 oil.
You could save some coin and get M1 EP instead.
Your good to follow the OLM on any DEXOS 1 oil. If Pennzoil Gold(a synthetic blend) would be able to do it, why wouldn't a so much better oil, Mobil 1 AP. be more than capable?
SuperTech Conventional would probably be fine for 2 years.
Mobil 1 AP? Yeah, it'll be fine.
Originally Posted By: rooflessVW
Mobil is in the business of selling oil.
I thought XM was in business to sell socks.
You're thinking of Fruit of the Loom
I emailed XOM about why they recommended annual oil changes. They said it's a warrantee issue. CVX didn't seem to understand my question and their reply didn't make much sense. To me at least. I leave regular M1 in my Ford vans for up to 5 years, That's about 7500 OCI. Haven't had any problems. I do recommend OEM filters if you can get them.
I have a couple generators that I use for a couple hours once every ten years or so. I have M1 in them. Am I going to throw that oil out after 2 hours ues? No. It would simply be a waste. Waste is waste.
I've been using the same tub of Kendall Super Blue grease that I bought in 1980 to pack the wheel bearings in my trucks for almost 40 years now. Despite reading by some authority on the internet that grease has a shelf life, I have never had a single bearing problem.
Right? It makes no sense. If the OLM programmed by GM says that Dexos 1 oil is fine, then it should be fine. GM backs their OLM with their warranty - if you follow the OLM and you have a problem, then GM will fix it if it's under warranty. End of discussion.
Originally Posted By: 4WD
The warranty is 12 months ~ it will not turn into a pumpkin at midnight … keep driving …
Aw man no pumpkin peices coming out of his next drain for exceeding 12 months?!
Well, might be safer to grow or buy them … and even then bake into a pie to be extra safe !
