Can I use Mobil 1 15W-50 in my bike, just like I use in my car? Mobil 1 is Mobil 1, right?
Mobil 1 for cars and Mobil 1 for motorcycles are markedly different. Every oil is a balance of benefits. Mobil 1 Tri-Synthetic™ Formula for cars has been developed specifically to satisfy car manufacturers' needs for increased fuel economy and low emissions.That's why new cars come with friction-modified, low-phosphorus 5W-30 motor oil. The low viscosity and the friction modifiers help fuel economy. The low phosphorus levels help protect catalytic converters.
So how is Mobil 1 for passenger cars different from Mobil 1 for motorcycles?
First, let's be clear about Mobil 1's overall benefits compared to those of conventional motor oils, whether for passenger cars or motorcycles:
Superior long-term engine protection.
Superior high-temperature stability.
Excellent low-temperature starting.
Outstanding engine performance.
Low volatility/low oil consumption.
It's a little hard to generalize about the difference between Mobil 1 passenger-car motor oils and Mobil 1 motorcycle oils. That's because not all viscosities of Mobil 1 passenger-car oils have the same levels of zinc and phosphorus, and there are even greater differences among the three Mobil 1 motorcycle oils. In general, Mobil 1 motorcycle oils have:
Different base stock systems.
Different additive packages.
Different formulations to meet very specific engine requirements.
back to top
What are the overall advantages of Mobil 1 motorcycle oils?
In addition to the overall benefits listed above – specifically, high-temperature stability and low volatility/low oil consumption – Mobil 1 synthetic motorcycle oils also offer superior anti-corrosion performance compared to conventional motor oil, which is important in many parts of the country where bikes may sit in garages for several months of the year.
Compared to conventional oils, Mobil 1 motorcycle oils have superior wear protection, engine cleanliness, high-temperature protection and lower oil consumption performance.
Once you get past these general advantages, you have to deal with each specific motorcycle oil one at a time to understand the benefits.
Okay. Let's start with Mobil 1 MX4T. What does it offer that Mobil 1 for cars doesn't?
Mobil 1 MX4T is designed for sport bikes. Most of these bikes have multi-cylinder/multi-valve engines and use a common sump, which means the engine oil lubricates the engine, transmission and wet clutch. So unlike Mobil 1 for cars, Mobil 1 MX4T has no friction modifiers, which could lead to clutch slippage.
The motorcycle oil also has more phosphorus/zinc for enhanced wear protection at high engine speeds and high loads. Remember, most bikes don’t have catalytic converters, so higher levels of phosphorus are not a problem.
In addition, Mobil 1 MX4T uses different dispersant/detergent technology for better high-temperature performance and engine cleanliness. Mobil 1 MX4T is also offered in a different viscosity grade than Mobil 1 for passenger cars.
Mobil flat out admitts there oils are more designed for EPA requirements then wear. First question sums it up.
