This has come up as of lately, again, and I'd like to get some opinions from others on whether or not ZDDP in an oil such as Mobil 1, is too low? Tooslick and I have been debating whether or not Mobil 1 valvetrain wear is higher then Amsoil's due to lower ZDDP levels. From my understanding, with Mobil now using 200ppm of Boron, high levels of calcium and a bit of Moly, the high levels of ZDDP are offset. I don't use the LS1 engine as a benchmark for this comparison as we have seen that LS1's like Thicker oils.
However, oils like Redline, Synergyn, Amsoil and M1R, all have very high amounts of ZDDP. So, would Mobil 1 be better off with more ZDDP and will the new GF-4 amounts be too low and sacrifice wear? From what others have stated, there are clearly better "more expensive" additives that will replace ZDDP and therefore it won't be a problem. Any guesses? Thanks in advance.
I currently have M1 5w-30 in my car with 1,400 miles on it. I took a qt of 15w-50 and mixed it in with the 1qt remaining in the 5qt jug so P should be higher. This will be my top up oil.
[ February 14, 2004, 04:53 PM: Message edited by: buster ]
![[Smile]](images/icons/smile.gif)
![[Cheers!]](/forums/graemlins/cheers.gif)
