Mobil 1 vs. PureOne for a 10K OCI
CA
Mobil 1 Mobil 1-205 versus the correct part# Purolator PureOne filter.
Is the Mobil 1 Filter significantly better performance wise compared to the PureOne filter? I plan on running it for 10K in a VW 2L with Mobil 1 Extended Performance 10w30.
I also recalled reading a while back that one of the filters (either Mobil 1 or PureOne), had some issues with being restrictive or having a less than ideal ADBV setup???
Thanks,
Mike
"Is the Mobil 1 Filter significantly better performance wise compared to the PureOne filter?"
No, IMHO.
After getting ripped by the local shop (to install the oil/filter), might have to run the oil/filter to 15K to recover the costs.
So, can the Mobil 1 Filter last 15K?
Yes...and so can a PureOne ..assuming the time frame is short enough.
Michael: What's the "E" (think HAL=IBM) does time have to do with it
BigG: Funny you should ask that Micael. You see, time tends to mean more starts. If the 15k is over a 9-12 month period ..well there's a good chance that the byproducts of start up are low enough to be handled well by the filter. OTOH, if it takes 2 years, who knows??? At that point the oil will probably have TBN depletion.
Run it 15k and do a PC on it.
