I was talking to buster earlier tonight and we noticed that there is not much of a difference in UOA results on long drains between Mobil 1 and Mobil 1 Extended Performance.
It is obvious that both oils are utilizing some sort of organic, non-metallic additive chemistry that is not showing up in the oil analysis results. Mobil 1's starting TBN is about 8.0, while the EP is 9.3.
The behavior of both oils on long drains is that the TBN seems to fall very rapidly to about 3.0 by 5,000 miles, but stabilizes and manages to stay above 2.0 on drains exceeding 10,000 miles. Viscosity and wear appear to be similar as well.
So, what's the difference between Mobil 1 Extended Performance and regular Mobil 1 aside from the possibility of a slight improvement in super long drains (past 10k)? From the information I've gathered so far, you may as well save the $2 and use regular Mobil 1 if your drains do not exceed 10k (or the OEM's normal-service interval).
Thoughts?
Thoughts?
