Mobil 1 Triple Action 5w30 EP VOA
NJ
I am running this now. SP VOAs are not that interesting to look at 😁
What version of "Triple Action" oil is this? There are different formulations of triple actions so that's why I'm asking.
Mobil 1
Edit: It appears it's the Extended Protection, according to you EP title, though I don't know if it's the High Mileage version.
Thanks, Sometimes I need to be talked to like I'm 10 to fully understand. :p
This oil is Mobil's best Full Synthetic, that's why I run it in my mower lol.
This oils low add pack is something I suppose we should not always look at. It does beg to question of some botique oils that are FS but come with a healthy dose of additives also adds to confusion. Perhaps the lower add pack is there to "meet specs" but still allow long run.
Thank you for posting this @buster. Judging by the low additive levels and Mobil's claim that their Triple Action+ motor oils have cleaning abilities, I'd say that this oil is loaded with alkylated naphthalene. Of course, it'd be nice to do FTIR analysis on a sample to confirm this.
Friends don't let friends clamor for PF oil tests.
This additive package is quite stripped down. Boron is low, detergents are low, and TBN is low, but that may not tell the whole story. At least this VOA is within grade, and the phosphorus within spec, unlike the Pennzoil Platinum High Mileage 5w30 posted recently.
The TBN here is 5.8 while Mobil 1's published TBN for this oil is 9.2. Blackstone uses a different method for determining TBN (D4739) compared to most other labs that use D2896. The difference between those methods is the strength of the acid used and the way it is administered. D4739, which is the lower result we see here, doesn't give a full picture of the reserve alkalinity as only the stronger base is titrated. That's why there's such a difference between these results and Mobil 1's published results. The D2896 method uses a stronger acid (perchloric acid) and more polar solvent system to fully measure both hard and soft base. Typically the difference will be ~2 TBN between the two methods, but it's >3 here, indicating a broader range of hard and soft base detergent additive content.
A reason for reducing additive content can be due to using higher quality base oils, that are more stable and oxidation resistant, and still meeting API requirements. Depending the cost of base oils and additives, as they tend to fluctuate (sometimes significantly), it may be a cheaper method of meeting the brand's standard. They could also be trying to lower valve deposits, though if they were already passing that test previously, there would be little incentive for a major brand to do that, so I'm a little skeptical to believe that. The most likely case is any reduction in deposits likely comes as a bonus to cost cutting measures with additives rather than the other way around.
Unfortunately, Mobil 1 doesn't publish (for this oil) all of the tests that would expose a superior base oil. We don't have CCS nor Noack data, two big indicators of base oil quality. We have MRV results (13,700 cP @ -35°C) which is decent. We have HTHS at "3" which could be a white washed number and not really a result to write about.
All in all... I don't know how I feel about this. I would need to see this oil run through PDSC, TGA, Teost 33c, and SRV in an A-B comparison with a previous SP or SN Plus formula to get a better picture of how it performs at this additive content.
These are the only specs for this oil I've seen. It's all speculation from SDS to patents etc. Fun to guess though. Sometimes the MSDS are informative to some extent. Even the SDSs vary from Amsoil using 40% III, RL majority PAO but Dave. G saying up to 40% POE. Even the oxidation correlation is speculation. Who knows..
I would like to think the latest Mobil 1 Extended Performance 5w30 is a quality synthetic oil perhaps also including additives not showing up during VOA tests .
If someone were to wake up from a multi-year coma and reach for a laptop on his hospital room's dresser, he could open this Forum Room inside BITOG and read this thread.
But his first impressions after seeing those numbers next to various additives, would be to think the UOA diagram was a mistake. He would swear to his Master in the Sky that there's a misprint..... has to be a misprint.
He would say "This is a VOA of a Mobil 1 oil that's guaranteed for 2k, not 20k"
