Mobil-1 Tri 10W30 Nissan 2000 1.8L 11,946 miles
Santa Cruz
I finally did the oil change on my Sentra. It went a little longer than I intended, as a few long trips came up right when I was due to change it.
It looks like I actually have a slight antifreeze leak. I had hoped that it was due to bad filtration from the fertilizer blowing around so I had a new OEM filter for this sample. It must be very slight, as I have not had to add any coolant.
My check engine light also came on shortly after the first sample that showed potassium. I was going to replace the O2 sensors shortly, and maybe they will show some indication of antifreeze contanimation.
code:
Mileage 56,126 65,917 76,946 8,399 100345
Date 03/28/02 10/01/02 04/22/03 10/20/03 08/18/04
Oil Miles 8,274 9,791 10,929 11,453 11,946
Oil Brand M1 Tri M1 Tri M1 Tri M1 Tri SL M1 Tri SL
Oil Grade 10W30 10W30 10W30 10W30 10W30
Make-up 0 0 8 Oz. .5 Qt. 0
Aluminum 2 3 4 3 3
Chromium 1 1 2 1 1
Iron 11 15 17 22 19
Copper 3 6 9 8 7
Lead 2 2 2 1 2
Tin 2 3 2 2 0
Molybdenum 2 1 1 71 55
Nickel 1 1 1 1 2
Manganese 0 1 1 1 1
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium N/A 16 17 20 24
Boron 49 42 47 107 82
Silicon 4 7 7 6 9
Sodium 16 18 17 21 21
Calcium 917 880 962 2803 3449
Magnesium 1547 1528 1708 231 43
Phosphorus 671 628 657 769 735
Zinc 832 765 926 973 842
Barium 0 0 0 0 0
TBN 8.5 9.5 10.5 5.5 5.3
SUS Viscosity
@ 210 F 61.0 67.0 67.9 66.0 65.0
Flashpoint
In degrees F 420 420 425 410 430
Fuel %
Antifreeze
% ? 0 ? ? ?
Water %
Insolubles
% 0.2 0.2 0.2 0.2 0.3
My comments: This is a California car, using the
special low sulfur gas to reduce emissions. I do not drive particularly hard most of the time. The vehicle is used primairly for long distance commuting and long interstate trips.
Comments for at 56,126 by Blackstone Laboratories: John: Universal averages show typical wear metals for an oil from this type engine after a routine oil run. Your oil was in use 8,274 miles, far longer than the 3950 miles this is a routine oil run for the type, and we found all wear from the engine below average and in the correct balance to show normal mechanical parts inside. Air and oil filtration were functioning normally while this oil was in use. This was 10W/30 engine oil with no gas, moisture or anti-freeze in it. The oil was not run too long. The TBN was 8.5, a routine level for this type oil.
Comments for at 65,917 by Blackstone Laboratories: John: Very little change since the last sample. All wear read at or below averages, wihich is a very good indication of normal wearing parts. It is especially good considering this oil was run almost 10,000 miles and the average oil use is only 4,000. The only thing we found that may be a concern is the sodium and potassium. Mobil 1 doesn't use either, so they may show a trace of anti-freeze. It is not affecting wear, so we suggest just keeping an eye on it. The TBN was 9.5, which is higher then the 8.5 last sample. Suggest going 12,000 miles on the next oil.
Comments for at 76,946 by Blackstone Laboratories: JOHN: The fact that this oil was in use about 1200 more miles than the last, yet the Na and K levels remained the same, is encouraging. If your Nissan has a coolant problem, it's very slight and it's not getting worse at this point. Wear levels still look good, so we are not too concerned about the possible coolant. Silicon remained steady at 7 ppm, showing no problems at the air filtration/induction system. Insolubles were low at 0.2%, showing very good oil filtration and complete combustion. TBN read 10.5, showing plenty of active additive remaining.
Comments for at 88,399 by Blackstone Laboratories: JOHN: No new problems showed up in this sample. You ran the oil longer and this is the reason for the mild increase in iron wear. The other metals all still look great, showing no mechanical problems. Unfortunately, we are still seeing evidence of anti-freeze getting into the oil. Since this problem is not getting any worse, we don't think it is a major concern at this point. The TBN was strong at 5.5, so the oil still has plenty of active additive left. Insolubles were low at 0.2% showing good oil filtration. Try 13,000 on the next oil and resample to monitor coolant.
Comments for at 100,345 by Blackstone Laboratories: JOHN: Mobil 1 doesn't use potassium or sodium, so we think these elements fround in your last four samples are from a minor anti-freeze seep into the oil sump. Nothing has really changed a significant amount in this sample, even though you've added 500 miles to your oil use interval. Wear still reads normally with only iron wear above average, probably due to miles oil use and not the contaminant. If your bearing metals stay low, we think the contaminant more a matter of interest than a problem. The TBN was 5.3, still plenty high.
Yea-like I mentioned on the Sentra Board. I think its a leaker. Hopefully someone else will comment. Great post. Good learning experience for other folks here.
New member cruising old UOAs. Noticed iron doubled and copper more than doubled between 3/28/02 change and 4/22/03 change. OCI only increased 32%.
10/20/03 change better, but still an increase in wear per mile vs shorter 8,274 mile interval for 3/28/02 change.
Are you adding antifreeze? With over 100K miles on the clock, with a 9 year old car, I would install Bar's Leak or similar additive to the antifreeze and "run her til' she drops". IMO, there is no purpose opening the engine up when there is minimal to no signs of wear related to the antifreeze. The 1.8 liter is a very good engine (minus the increased incidence of head gasket failures) so the rest of the car will probably fall apart before the engine does. Good luck.
The original post occurred 4.5 years ago and according to the records it's the last post johnk made.
But, I think for the miles run that these were very good UOA's. All metal wear was excellent.
Who found this old post? As soon as I saw the oil was Mobil 1 Tri I thought what the heck is up here................
Harley,
What kind of shovel did you use?
LOL!...Just kiddin'
This most be the "Good" Mobil 1.................
