Mobil 1 threatened by SuperTech!
I don't know if it cleans better or not but with Mobil one the oil doesn't get that burnt smell at 4k. The Supertech smelled old or burnt, as if it had been in there for 10k or more. With Mobil 1 there's nothing to 'clean'. I had my doubts if the Supertech was really pure synthetic. It doesn't feel the same between your fingers as Mobil one, the same weight oil feels thinner and less slippery somehow. It reminds me more of the Motorcraft Synthetic Blend oil that Ford sells.
I only ran the Supertech once in that car, right away I noticed the noise on start up, and when I got that stuff out of there and went back to Mobil 1, the noise was gone. The car only has 25,000 miles on the engine, I bought it new, it rarely gets driven. I have the same engine in a same year Grand Marquis too. The Mercury has only ever had Mobil 1 5W-30, the engine inside is spotless, that one round of Supertech left the Ford's engine stained brown inside, under the oil cap and around the filter area. Before that it looked new. To be fair, neither car sees more than a few hundred miles a year but I won't likely ever use Super Tech again in my cars or trucks.
I don't think its bad oil but its not Mobil 1.
My last Crown Vic, a 1990, ran 265,090 miles on nothing but Mobil 1, when I pulled the engine for a freshen up, it was like new inside. I ran a ball hone through it, fit some new rings and bearings and put it back in I ran it for two more years till my ex totaled it at 301k. I kept the motor, it’s in a buddies pickup still today.
I get we all have our own personal experiences but things like "it doesn't feel the same between your fingers so I doubt its full synthetic" are... not really useful.
And yes to some extent a more expensive oil may perform better, but fleets of Crown Vics and other Ford modular engines around the country, most of which get treated way worse than a personally owned vehicle, received the cheapest bulk oil for decades, and while engine failures did happen they were rare and far between.
The only thing that I know of and had personal experience with startup clatter on Fords (including multiple Crown Vics) was oil filter. Some brands and designs of oil filter could make a big difference with that.
I bought a couple Mobil 1 ESP 0w30 5qt jugs for my wife's 1.3L Trailblazer. I saw that $25 price and figured I should pull the trigger.
I get it that how it feels between your fingers is far from scientific but I've been around trucks my whole life, worked for 35 years in a dealer shop.
Mobil 1, is slick to the touch, if you dip your fingers in it then try to pickup a flat screwdriver by the blade tip, its not happening, but with the Super Tech, its not a problem. Its not scientific but its also a clear sign they're different by a mile in lubricity. Don't get me wrong, I'm not saying Super Tech is bad oil, from my experience, its just not as good as Mobil 1.
I've used other synthetic oils, and Super Tech is the only one that ever gave me cause to wonder if it were really on the same playing field. In other motors, small engines and such, I've not had any issues but I have had a few motors that didn't seem to like it.
I put Super Tech 10w-30 synthetic in my Cub Cadet riding tractor with a CH15 motor, it used oil bad on it, I'd had a half pint every time I mowed. When i switched back to cheaper Dino oil, the oil consumption and leaks were gone.
Again, not bad oil, just not right for that motor. In my Briggs engines and Kohler Command twin cylinder its been fine. SIde by side, both 10w-30 weight oil, the Mobil 1 is thicker out of the bottle, not by a lot but enough to be noticeable. At below 20°F the Mobil 1 is still very viscous, the Super Tech thicknens quite a bit.
I've got an old junk Allis Chalmers garden tractor out back, I use it to drag things around the yard, to haul firewood up to the house and such. It sits outside 24/7, the hood barely covers the engine and its been known to get rain water down the the intake if it happens to not be covered. I've used my used Mobil 1 oil out of my 86 Ford truck, I've used 10w-30 in that thing now for 40 years. Since that truck don't get driven much I try to change it ever two or three years no matter what, usually its only got a thousand or so miles on it. The tractor leaks and burns oil, and has for as long as I've owned it. When the Mobil 1 comes out, it still oil still slippery and it don't smell like burn asphalt.
When I drain out the SuperTech oil it’s burnt looking, dark, and it looks like runny molasses. Mobil 1 will get dark too if you leave it too long but it’s never gotten to the point it looked like I could stain wood with it.
I've never done enough checking but the Mercury uses less gas with Mobil 1, and the difference is enough to notice.
I didn't realize it until recently when I started looking to buy gas when I was out of this area. I travel regularly to another property I own in PA, about a 5 hour drive from here. When I had the SuperTech oil in the Mercury, I could not make that ride on one tank of gas, I could get there but was risking running out of gas by the time I got back to the nearest gas station coming home. I sort of figured it was just the hills or the time o year, but now I'm a full year back on Mobil 1, and I've been back and forth to PA three times, and it will make it nearly there and back on one tank. It may actually even make it all the way back but I never cared to chance it. I got 16-18 mpg on SuperTech, I get 20-24 on Mobil 1, but again, not scientific, but the difference is enough to notice. When I put the Supertech in the car I was living in PA, it took four years to put enough miles on the car to need an oil change, the Mobil 1 in it now was put in a year ago, about 1,200 miles or so back. (The car is a 2003 with 43,011 miles on it as of this morning.
The 4.6L is by far their best motor, my 1998 CV, which I bought with 21k on it, had 368k on it when I sold it, my 2002 Town Car had 391k, and lived most of its life on what ever oil the dealer had in their tank. We didn't get charged for oil and filters, which is why I have a lifetime supply on hand for these motors. Its also why there's a 4.6L and CV chassis sitting under the 56 Ford Country Wagon I bought a few years back with a bad frame. A retired police cruiser with 69k on it donated its lower bits. I swapped in a Mustang rear fitted to the CV chassis gave me the 3.55 gears and the 56" width to let me use the stock 56 wheel up front we used aftermarket spindles and custom tubular A arms to narrow up the front to match. Both bodies had 115" wb. (144.7 in 02, 115.3 in '56).
The stock 4.6 and fresh rebuilt 4R70W transmission should make that thing a very reliable driver when ever I get around to getting back to it. We did my buddy's 59 Ford panel with a 99 CV chassis about 15 years ago, he drove that thing daily till the day he died in his late 80's. I lost track of it, his kid sold it fast to the first person who waved a few bucks at him. I'd have bought it and kept it but he dumped it before his dad was even in the ground. I doubt he even knew what was under that thing, the buyer may not have either.
How something feels is not data, it is an opinion.
Plenty of UOA's showing Supertech is fine if the end user is following grade and listed specifications are being adhered to and staying within the vehicle manufactured OCI intervals.
I don't now or ever look at Supertech and won't ever - Mobil 1 for my Tacoma, Castrol for the Mazda. I'm sure there are plenty of folks talking about "as long as you change it ever 3,000" but Supertech is "oil" like Snickers bars are "food".
Well, with SuperTech oil prices reaching Mobil 1 prices, which one do you think an average Joe or Jane will buy at WM? I witnessed many times that far from wealthy guys and gals shopping for oil in US WM would go straight for Mobil 1 not even glancing or considering other oils while looking for a sale on Mobil 1. In Canada thou, many or most people favor Castrol for some reason, possibly since it's made here but it's also sold at Costco as opposed to Mobil 1 in USA? To me, brand name doesn't matter so much but what the product itself has to offer. SuperTech and Kirkland didn't work well in our 2 Kias.
I agree, but in my situation, it didn't work well for me in my two cars, both had start up rattle with it, both SuperTech and Mobil 1 were 5W-30 synthetic oils, I can run 5k with Mobil 1 with no issues, no burnt oil, and the oil don't look like yesterday's coffee. With the SuperTech oil in the CV or GMarq, the oil came out of both low mile cars looking like it was completely cooked and smelling burnt. I don't get that on older motors, I run the SuperTech in my 5.7L in a 97 K1500, it gets changed at 4k, with no issues, and the engine doesn't sound any different than with Mobil 1 oil.
The SuperTech oil does get dirtier though but not enough to set of any alarms. It actually acts the same as regular oil dirt wise.
Like on the Grand Marquis, the GMC gets a few more mpg on Mobil 1 than the Super Tech and winter starting is a bit easier but that motor has 323k on it now. It gets changed more often now that its likely in its final round. Its days are numbered and its replacement is on a stand in the garage, and has been since 2005. (I didn't figure it would go this far because it was very much abused by the last owner, a relative who didn't believe in changing oil, he just let it leak and kept topping it off.
I got it at 181k with a bad front seal, bad water pump, leaking pan gasket, and blue silicone filling in the missing chunks of valve cover gasket on both sides. I resealed it fixed the PVC system, and ran it while hunting down a low mileage motor. Its replacement is out of a 97 Chevy that a tree fell on at 11k back in 1999.
Its on a stand set up to run on the stand so I can run it every so often until its needed.
I still buy SuperTech Synthetic when I find it cheap enough, WM here just had 5 gallon pails marked down in the area where they have all the heavy truck oil and Antifreeze, and RV stuff. $68 for 5 gallons on clearance. I bought four buckets of it in 10w-30
For my cars and newer trucks, I have Mobil 1 in a drum
