Not to sound stupid, but if dirty oil is going into a filter and clean oil is coming out, how can a filter bypass clean oil? By definition, bypassed oil is dirty oil. Isn't it?
![confused.gif](https://bobistheoilguy.com/forums/images/icons/confused.gif)
I guess I should clarify dirty oil. By dirty I mean at the bottom of the filter housing is theoretically the dirtiest oil due to gravity and any solids should fall to the bottom. If the bypass valve is on the bottom side, then when it goes into bypass, then you would be bypassing the worst of the unfiltered oil. However, if the bypass valve is on the top side , then you would bypass a cleaner version of the unfiltered oil.quote:
Originally posted by GlenFord:
Not to sound stupid, but if dirty oil is going into a filter and clean oil is coming out, how can a filter bypass clean oil? By definition, bypassed oil is dirty oil. Isn't it?![]()
Don't forget that even with the bypass valve open, it still maintains the specified pressure differential across the filter media. If the filter has an 8 psid bypass, when the bypass opens there's still 8 psi holding the dirt into the media, and part of the oil is still passing through the media due to that pressure differential (unless the media is completely clogged).quote:
Originally posted by neilw:
I can see where when the filters goes into by-pass with the by-pass valve in the dome the dirty oil will pass the full length of the dirty filter material in order to make it to the filtered side of the system.
Bosch may be my next oil filter.
quote:
Originally posted by Patman:
I think you guys are thinking of the SHO oil filter article that I posted here, in particular this section of it:
http://www.shoclub.com/lubrication-oil/lubrication-oilpart2.htm
Patman, sorry that I did not remember that you were the one who posted it. I have read so many threads that I forget where they came from sometimes.quote:
Patman,quote:
I still am not comfortable running the PureONEs on my cars. Cost isn't a big issue, as they are only a couple of bucks more up here than the Premium Plus filters. I just worry that the PureONEs filter too good, and will end up going into bypass too often. Since they aren't a fully synthetic media like the Mobil 1, I don't believe they can do as good of a job at oil flow as the Mobil 1 will. We don't have the Mobil 1s up here. We also don't have the Bosch Premiums, but in looking at their specs I would probably use them if they were up here, especially since their price isn't too bad. The Bosch premiums score a 93% on the Multipass efficiency test.
For my money though, it looks like the regular Purolator Premium Plus filters fit the bill just nicely.
I don't remember which site it was. It was either the pickuptruck.com or stangnet.com website.quote:
Kevin in Texas
I was curious about what the Ford forum was calling the by-pass in the bottom of the filter.
