mobil 1 filters cost $12 compared to ac deco at $3.50. I'm running mobil 1 5w-30 and plan on changing it out at 3000 or 4000 miles. Is the mobil 1 worth the price at this milage?
![confused.gif](https://bobistheoilguy.com/forums/images/icons/confused.gif)
Mine does, 3000 under severe service schedule B. I have a 2001 model yearquote:
Originally posted by Ken:
What owner's manual requires an oil change before 5000 miles these days?
Ken
Pat what percent of the particles are removed at the 10 micron level? I would guess not very much, maybe 30-40%.quote:
Originally posted by Patman:
The Mobil 1 filters definitely keep the oil cleaner than an AC Delco does. The AC Delco
stops mostly 25 microns and larger, while the M1 stops as low as 10.
Also note that the above list the effeciency in the 10-20 micron range(pretty broad huh?) So in essence it could remove 99% at 20 microns and only 50% at 10 microns and still list a combined effecincy of 96% in the 10-20 micron range.quote:
The filter box shows single-pass efficiency and multiple-pass efficiency data. What do these numbers mean?
Oil filter efficiency in a circulating system like your engine is rated on two key factors: The size of the contaminants you want to remove, and the number of passes through the filter needed to remove these contaminants.
For a single-pass test, an oil sample is intentionally contaminated with glass beads in a known size (very small beads in our case). The oil is then passed through the filter and the level of contamination is measured after filtration. The Mobil 1 High Efficiency Oil Filter has a single-pass efficiency of 98 percent for 10- to 20-micron contaminants vs. an average of 85 percent for conventional filters.
The multiple-pass test is similar to the single-pass, except oil is repeatedly passed through the filter. In a circulating system, the oil flows through the filter many times, so multiple-pass filtration is often used as the more important comparison vs. the single-pass result. The contaminant used for multiple-pass testing is a standardized test dust. The Mobil 1 High Efficiency Oil Filter has a multiple-pass efficiency of 96 percent vs. an average of 82 percent for conventional oil filters.
In short, the higher the efficiency for a given contaminant size, the more contaminant material the filter is removing from the liquid. And the Mobil 1 High Efficiency Oil Filter does a significantly better job than conventional oil filters.
I think the Normal/Severe oil changes are a way to give the manufacturer an extra margin of comfort in terms of the vehicle reaching its "Sorry - no more warranty, buddy" I therefore believe in self preservation and choose to do what I think is best for me and my vehicle. Even Mobil has said that you can run your vehicle up to the maximum period of the milage/time irregardless of your driving conditions. As was mentioned oil analysis will prove that the oil is in acceptable condition. However as far as the manufacturer is concerned: I have enough filter receipts and oil receipts, that I can give them anything they want. Do I feel guilty about deceiving them?? :freak : uh-no.quote:
Ken
Here's what Mobil says about their M1 filters:quote:
Nothing will outperform Mobil 1 oil filters with the exception of the Amsoil filter by a small margin.The PureOne is just a tick under the M1. M1 filters have gotten pricey these days, up by about 2 dollars.
Purolator states on their boxes that they use the J806 test (multiple pass) but I haven't seen the numbers. Anyone have them?quote:
...The PureOne is just a tick under the M1. M1 filters have gotten pricey these days, up by about 2 dollars.
Amsoil doesn't test their filters with the multiple-pass test. I asked them.
Ken
Patman, since you have the purolator catalog, maybe you can answer this question?quote:
A Purolator tech rep told me their Premium Plus filters score a 96% on the multipass test. So the PureONEs would (or should) be better than this.
