Mobil 1 M1-210a C&P
BrendanC
$100 site donor 2024
Houston, TX
2010 ford explorer sport trac 4.0
in service 5900 miles
out/off: 6 quarts Mobil 1 EP HM 5w-30 with Mobil 1 M1-210a
in/on: 6 quarts Valvoline EP HM 5w-30 with carquest premium 85372 (PG with silicone gasket)
filter held up well.
If you can get one of these affordably great but there are better 20,000 mile rated filters available like the Purolator Boss. I would not run this for 20k. Thanks for the cutting these.
Very nice work. Thank You for cut and post
There is nothing wrong with that filter. It could easily have went much, much longer. With it's 20k mile rating, you could easily have went two oil changes on that filter. M1 oil filters have always looked good when cut open and shared, here on BITOG.
Thanks for sharing.
Thanks for sharing.
incorrect. two M1-212A’s have been posted torn in the last month. there will be no more mann&hummel filters going on any of our vehicles unless they’re mesh backed.
The M+H/Purolator flat bypass spring incorporation. Media must be pretty stiff for that wide pleat to not bend over some.
