Originally Posted By: tig1
What engines have you torn down that used Mobil 1? What was their condition?
I'm not the one you directed that question at, but FWIW I did a re-gasket on my wife's former 1993 Chrysler 3.5L (first-gen) v6 a couple of years ago. We recently sold it with 257,000 on the clock, and at the time I did the re-gasket it had about 225,000 on it. I ran it on Mobil 1 10w30 from the time it had about 15,000 miles onward. The internals were very clean- not even any yellowish discoloration on the top end. Visible head casting material was still white/silver aluminum, iron parts were still grey/black, wear areas silver, cams were spotless. Even the casting areas directly atop the exhaust ports were not yellowed as I've seen on many engines and older non-synthetic oils. On the bottom end- same story. Looking at the cylinder walls there was no scoring or glazing, and the factory honing cross-hatch was still visible. Tempted as I was, I didn't pop off a bearing cap to take a look there since oil pressure was still fine, and I wasn't planning to keep it long enough to bother rolling in new bearing shells even if they were worn out. Oil consumption was about 1 quart per 5k miles when we sold it last fall.
I'm not saying that it wouldn't have been just the same on another oil, just a single data point- nothing to draw a "trend" through, that's for sure! One thing that has been in Mobil 1's favor, at least for me, is that they've been around a long time. Many oils on the market now (eg. PP) didn't even exist when we bought that car. The other side of the coin is that the Mobil 1 10w30 I started that car on in 1993 was a different substance from the last batch I poured into it in 2008. Would it have performed the same if it had run its entire life on 2008-vintage Mobil 1? Who knows. Oils change a heck of a lot faster than I wear out engines, so drawing meaningful conclusions about today's oil from engine longevity is dicey at best.
