Mobil 1 High Mileage
USA
I always feel a little silly asking an oil related question on this site because I'm sure most topics have been covered many times before. But here goes.
What are people's opinions on using M1 High Mileage oil in a vehicle with 75k on it? I use it in my daughter's old Yaris without much thought. It's 10 years old with a ton of miles on it.
But my 5 year old 4.0 Tacoma is due for it's next change at 75k miles. I'm not falling for the marketing per say. But it seems like the HM formula has a good additive package and people have had some good OA from it. I noticed recently that it's SN/SN Plus rated...and that's obviously what my Taco calls for. I can get it for about the same price as M1.
And this would be in the 5w30 flavor.
Thoughts?
Yesterday's 75k vehicles are today's 125k vehicles.
If your engine is not showing any symptoms for need, then continue-on with regular synthetic oil.
We dont use any High Mileage oils, Mobil 1 recommends to use 5w-50 in older engines with 300-500k km. I think its marketing with the High Mileage oils when a euro oil will work better. I would use Mobil 1 0w-40 in that engine or the Mobil 1 ESP 5w30.
I've owned vehicles with many more miles than that on them. I have never used High Mileage oil.
If you don't have any weeps then I would continue to use what you have been using.
I agree ^^^^^^^^^
No change needed.
I agree with the others. No need for High Mileage oil in your Taco. If you're not experiencing any leaks, blowby or smoking then do what you've been doing.
High Mileage oil is not going to hurt your car. I use it off and on like currently. Got some Pennzoil 5W-20 for $4 a Jug after rebate. Its in my Corolla has about 3K miles on it currently it is working out just fine. Some people just spend more time worrying than is needed. It will be just fine and yes the next time High Mileage oil is on a sale with a good rebate will I buy it again? You bet I will.
Maxlife is one of the best High Mileage oils available and its on every street corner where you guys are!
M1 is a well known name with a big reputation but it will make your valvetrain super-noisy.
Stick with Valvoline MaxLife.
Can't really go wrong either way. Some still link High Mileage oil to the old days of "seal swellers" additives that would stop a car from leaking for a while as long as you kept using the seal sweller. The moment you stopped using it the seals would retract and leak even more than before you started.
Modern High Mileage oil don't do that. (according to the manufacturers) These are seal conditioners which prevent the seals from getting hard and shrinking in the first place. Sort of like armor all for your seals. (No Armorall flame wars please, replace with your favorite rubber protectant if you will)
While you don't need a High Mileage oil, it won't hurt a thing.
The engine is drum tight. No leaking, weeping, burning, etc.
One thing that caught my eye is that Mobil 1 High Mileage seems to be on the heavier side of the 5w30 spectrum. That I like. And it's basically the same price as M1. I typically use Mobil 1 and buy it either when it's on sale or has rebates.
I figured I might get a range of answers. I appreciate everyone's opinion. I'll add that I've seen no issues at all with it in my daughter's Yaris....other than the first couple of changes being very black. I'm assuming that's because of it supposedly heavy detergent pack. The oil stays a golden color these days.
Keep the opinions and info coming. And anyone out there with some personal OA numbers....jump in.
Not necessarily "the moment", it can take a while for the seals to shrink again, even many miles, so people who flip back and forth, don't see the direct correlation between their premature seal wear and the High Mileage oil.
Quote
This is a false statement without a qualifier of which manufacturer you're talking about. Valvoline Maxlife for example, does in fact do this according to representatives.
Quote
Show us a statement that they work like armor all instead of like a seal sweller. That's not even how the are marketed, if they had only benefits they would be called "advanced protection" rather than "high mileage".
There is no conditioner for seals that can keep them from aging. Conditioner is marketing department doubletalk because seal sweller can be a dirty pair of words, as they have seen from public discussion. It is a deliberately vague, non-specific word that does not mean it's like armor all.
The effects of swellers aka seal conditioners depends on the material the seal is made from. There is nothing that I know of that will swell a PTFE seal and that is what some of the seals in your Toyota's are especially the mains and probably cam seals, the others are mostly Viton which is very resistant to chemicals that will cause swelling.
Some parts use no gaskets but instead a silicone sealer which does not like these sorts of chemicals and can soften and leak in time. In the amount these chemicals (mostly esters IIRC) are found in approved engine oils they are basically harmless.
Old seal types like Buna-N will swell readily and stop leaks doing so but they return to their shrunken state in time. This is an o ring compatibility chart, the material in seals is the same. The bottom line is you can use HM or not with the seal your engines use it probably wont make much of a difference one way or the other to the seals.
https://www.allorings.com/o-ring-compatibility
M1 in the correct range will not affect most valve trains. Some of the less well designed ones, it will make noisy, others will get quieter.
rod
I have moved my high mileage Toyota to Mobil 1 0W-40. If you search you will find a lot of people have done this with Toyota trucks. But, I was also considering 5w30 ESP. Anyone know if there is an advantage of one over the other?
Those Mobil 1 products works really good in Toyota engine
My Tacoma's 4.0L just turned 90K. Currently using AMSOIL Signature Series 5w30. Back when I had my 3.4L I used Mobil 1 High Mileage 5w30, no issues.
I use Mobil 1 High Mileage 5w30 flavor in a couple of my vehicles. No leaks, running good and not noisy at all. The vehicles are a CTS with the 3.6DI (168k mi), a GMC Denali with the 6.0L (166k mi)and a Jeep GC with the 3.6 (116k mi). All have been on HM Mobil 1 since around 80k miles.
