Mobil 1 High Mileage is API SL-rated. I asked the Mobil Tech line whether it would be an appropriate oil to use in a 2005 model where the specification is API SM. Mobil responded th only reason it was not (and will not be) SM rated was because it contains higher levels of zinc as an anti-wear additive.
Is anyone using Mobil 1 High Mileage in a car that specs SM? See any problem in doing so?
Thanks.
Thanks.
