I am encouraged and will use Amsoil 0W30 for annual changes (12k to 15k miles)
From Blackstone comments:
Everything looks good in the first sample from your Prius. You ran this oil almost 12,000 miles and
all wear read around averages. Those averages are based on an oil run of ~6,800 miles for this type of
engine, so your engine is wearing better than most considering the long oil change. The TBN read 2.4, so
this oil still has lots of active additive remaining. 1.0 is too low. No fuel or coolant found and air and oil
filtration look good. Since you're interested in longer oil changes and your engine looks great, we suggest
going to 13K-14K miles for the next sample.
