Originally Posted by Patman
I just found out today on the Corvette Forum that this oil can be ordered online from Walmart.com (it's not in stores or available for pickup at this time though) The price is pretty good too, $54.99 for 6 quarts, plus $8.99 for shipping (that's a lot less than dealers are charging for it)
Here's the link:
https://www.walmart.com/ip/Mobil1-1...u1qPz4AIVCj0MCh0EegdXEAQYAiABEgIZC_D_BwE
No, the price is
not pretty good. In fact, it's a rip-off.
You're paying boutique-oil price for a plain Group III oil with a dash of ester -- no PAO, no GTL.
Oil recommendation for this car:
Street use only (except the LT5 engine): 5w30 dexos1
Street and/or track use: 0W-40 dexos2
Track use only: Mobil 1 15W-50
If I was not racing the car, I would use 5w30, as it would give better performance (better fuel economy, morse horsepower at a given throttle angle, smoother-running engine) and it's much easier to find. Also, 5w30 has PAO or GTL, which means higher oil quality. I don't know if you have turbo but you get LSPI protection, too -- something dexos2 doesn't have.
Just put a dexos1 5w30 (PPPP has about 6% VII and Mobil 1 Extended Performance has about 13% VII) and a From Ultra and forget about it.
From the 2019 Corvette owner's manual:
Engine Oil
Caution
If the vehicle is used for track
events and competitive driving,
the engine may use more oil than
it would with normal use. Low oil
levels can damage the engine.
Check the oil level often and
maintain the proper level. See
Engine Oil 0 232.
The engine is factory filled with
0W-40 dexos2 oil. For LT1 and LT4
engines only, 0W-40 dexos2 engine
oil is approved for both track and
street use. 15W-50 full synthetic
engine oil may also be used for
track use, but after track use must
be changed back to 0W-40 dexos2
for street use. If 0W-40 dexos2 oil is
not available, 5w30 dexos1 full
synthetic engine oil may be used for
street use. If 5w30 dexos1 is used,
it must be changed to 0W-40
dexos2 or 15W-50 full synthetic
engine oil for track use.
For the LT5 engine, SAE 15W-50
full synthetic engine oil must be
used for track use, but after track
use must be changed back to
0W-40 dexos2 for street use.
Z51 Performance Package, Grand
Sport, Z06, and ZR1: Check the oil
level often during track events and
competitive driving and keep the
level at or near 0.5 L (0.5 qt) above
the upper mark that shows the
proper operating range on the
engine oil dipstick. After the
competitive driving, remove excess
oil so that the level on the dipstick is
not above the upper mark that
shows the proper operating range.
Driving and Operating 163
Stingray without Z51 Performance
Package: Additional oil fill above the
upper mark on the dipstick is not
recommended for track events or
other competitive driving. Check the
oil level often during racing or other
level at or near the upper mark that
on the engine oil dipstick. After the
Fuel
LT1 Engine : 93 octane (or higher)
unleaded gasoline is required.
LT4 Engine : 93 octane (or higher)
100 octane (or higher) unleaded
gasoline is recommended at the
track when temperatures are above
30 °C (86 °F) to maximize
powertrain performance and
improve longevity of components
within the powertrain.
LT5 Engine : 93 octane (or higher)
gasoline is recommended to
maximize powertrain performance
and improve longevity of
components within the powertrain.
Caution
Some high octane fuels contain
additives and compounds that
may damage the vehicle and void
the vehicle warranty. See
Prohibited Fuels 0 213.
Automatic Transmission Fluid
Transmission fluid should be
changed after every 15 hours of
track usage. Any transmission level
set or change should be performed
at your dealer.
Manual Transmission Fluid
Manual transmission fluid should be
track usage.
Load Limit
Z51 Performance Package Only:
Limit vehicle load to the driver only,
with no other cargo. Inflate tires to
180 kPa (26 psi) and drive at a
maximum speed of 280 km/h
(174 mph).
Grand Sport, Z06, and ZR1 Only:
maximum speed of 296 km/h
(184 mph).
