- Joined
- Nov 24, 2022
- Messages
- 75
witch one of those two would you choose and why, do you think one is better than the other ?
Yeah, I used a jug of the Triple Action before I read about the change and was disappointed that it didn't have PAO anymore. Now that Mobil 1 uses GTL, why not just use Pennzoil, which right now is six dollars cheaper at Walmart? Takes the shine off of M1 for me a bit, even though I still like them overall.I prefer Mobil but I’m leery of this triple Action formula that doesn’t contain the PAO
View attachment 127766View attachment 127767
6.2 L gm truck engineFor what application?
but its fun to read what people post, the chances are those 2 oils will perform identical anyways, I have never use castrol I might give it a try this time.....You will not get the answer you are looking for.
The Castrol EDGE Extended Performance 0w-20 is the same oil as Castrol EDGE C5 0W-20 sold in Europe. It's a MB 229.71 additive package, meant to keep light duty small displacement Turbo Diesel, T-GDI, and GDI engines clean. It works well for large displacement GDI engines as well. For your application it would be the better oil.6.2 L gm truck engine
you do that !! .....lolI'll take the Legend of Zelda bottle
my engine is a direct injection , I to think that castrol will do better, tomorrow , Walmart here is come, I hope they have it in stock.The Castrol EDGE Extended Performance 0w-20 is the same oil as Castrol EDGE C5 0W-20 sold in Europe. It's a MB 229.71 additive package, meant to keep light duty small displacement Turbo Diesel, T-GDI, and GDI engines clean. It works well for large displacement GDI engines as well. For your application it would be the better oil.
While Mobil 1 Extended Performance 0w20 is very good oil, you should compare Castrol EDGE Extended Performance 0w-20 with Mobil 1 X2 0W-20. Mobil 1 Extended Performance 0w20 will do well in your engine, however, for your application, I'd give Castrol the edge. If you were running it in a 5.7 HEMI, I'd say go for Mobil 1 Extended Performance 0w20.
I hope this helps.
ignore the weight ,its just a picture to show the brand .One oil is a 5W the other is a 0W, Both are extended life oils, are you going to run the oils for extended oil change intervals? The question should be which oil would produce less wear and or keep the engine cleaner . I am positive there are differences, they are both oils by quality oil companies . I doubt you will during the ownership of your vehicle all things equal not see any difference in engine life with either of those oils. Just because the oil is a long life oil doesn't mean it will protect the engine from wear better that an oil without the long life additives. I would go out on a limb and say the regular M1 or Quakerstate oil, would have less wear. What ever oil from the majors you chose will allow engine life beyond your ownership .
What's Mobil 1 X2?you should compare Castrol EDGE Extended Performance 0w-20 with Mobil 1 X2 0W-20.
anyone know what base oil castrol use ? group III or IV ?
