Blackstone Laboratories
Oil Report
EQUIPMENT MAKE: GM
OIL USE INTERVAL: 7,527 Miles
EQUIPMENT MODEL: 2.2L
OIL TYPE & GRADE: Mobil 1 5W/30 EP
FUEL TYPE: Gasoline (Unleaded)
MAKE-UP OIL ADDED: 0 qts
SAMPLE DATE = 03/21/07
MI/HR ON OIL = 7,527
MI/HR ON UNIT = 9,055
Blackstone's comments:
"Let your engine get completely past wear-in before you get too crazy with the oil use intervals. Our average oil from this type engine has 3,280 miles on it, but it is a new averaged file, so the miles will creep higher in time, and so probably will the wear levels. Iron will tend to run high when you run longer than average oil use runs. No problem with this, unless it makes the oil abrasive enough that it starts getting into the bearings, which will cause increasing lead. So far, so good on the lead. Stay at 7,500 miles next sample for another look. The TBN was 3.2, still okay."
Oil Report
Sample: Unit Location Averages: Universal Averages
ALUMINUM = 5, 5, 4
CHROMIUM = 1, 1, 0
IRON = 26, 26, 12
COPPER = 5, 5, 3
LEAD = 1, 1, 1
TIN = 1, 1, 1
MOLYBDENUM = 69, 69, 53
NICKEL = 1, 1, 0
MANGANESE = 3, 3, 1
SILVER = 0, 0, 0
TITANIUM = 0, 0, 0
POTASSIUM = 1, 1, 1
BORON = 59, 59, 41
SILICON = 16, 16, 8
SODIUM = 7, 7, 12
CALCIUM = 2269, 2269, 1995
MAGNESIUM = 12, 12, 183
PHOSPHORUS = 592, 592, 707
ZINC = 658, 658, 821
BARIUM = 0, 0, 0
SUS Viscosity@210 degrees F
Values Should Be: 56-63
Tested Values Were = 56.4
Flash Point In degrees F
Values Should Be: >365
Tested Values Were: 375
Fuel %
Values Should Be: Tested Values Were:
Antifreeze %
Values Should Be: 0
Tested Values Were: 0
Water %
Values Should Be: 0.0
Tested Values Were: 0.0
Insolubles %
Values Should Be: Tested Values Were: 0.3
---------------------------End of Report------------------
Oil Report
EQUIPMENT MAKE: GM
Oil Report
ALUMINUM = 5, 5, 4
CHROMIUM = 1, 1, 0
IRON = 26, 26, 12
COPPER = 5, 5, 3
LEAD = 1, 1, 1
TIN = 1, 1, 1
NICKEL = 1, 1, 0
MANGANESE = 3, 3, 1
SILVER = 0, 0, 0
TITANIUM = 0, 0, 0
POTASSIUM = 1, 1, 1
BORON = 59, 59, 41
SILICON = 16, 16, 8
SODIUM = 7, 7, 12
BARIUM = 0, 0, 0
Fuel %
Antifreeze %
Values Should Be: 0
Water %
Insolubles %
