Mobil 1 EP 5-20 5500 mi in V-10
WV
Thought you guys might want to see this. It's a great oil but don't think I would go 15k on it. This trip was an RV pulling a motorcycle trailer across the country and western mtns. LAB NUMBER: G95203 UNIT ID: RV OIL REPORT DATE: 8/14/2015 CLIENT ID: 71535 REPORT CODE: 83/501 PAYMENT: Prepaid (Typewriter comment blank) (Typewriter comment blank) TFord 6.8L 418 CID V-10MAKE/MODEL: OIL TYPE & GRADE: Mobil 1 5W/20 Extended Performanc UNIGasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 5,500 Miles 2014ADDITIONAL INFO: COMMENTSSTEVE: Thanks for the notes about the towing and hard use through the mountains. Your V-10 handledthat well. For such a new engine, we honestly expected more residual wear-in metal since that can take awhile to wash out, but it's not here. Universal averages show typical wear levels for this type of engine afterabout 4,400 miles on the oil and this engine compares nicely. Silicon is probably harmless sealers washingout, but you can always check the air filtration system just to be safe. The TBN is 3.3 showing activeadditive left. Try 7,500 miles next and check back. ELEMENTS IN PARTS PER MILLION MI/HR on Oil 5,500 UNIVERSAL AVERAGES MI/HR on Unit 7,500 UNIT / Sample Date 8/5/2015 AVERAGES LOCATION Make Up Oil Added 0 qts ALUMINUM 6 6 5CHROMIUM 1 1 1IRON 32 32 19COPPER 5 5 5LEAD 0 0 1TIN 0 0 1MOLYBDENUM 77 77 65NICKEL 1 1 1MANGANESE 2 2 1SILVER 0 0 0TITANIUM 0 0 0POTASSIUM 6 6 2BORON 44 44 51SILICON 51 51 19SODIUM 13 13 41CALCIUM 1211 1211 2127MAGNESIUM 712 712 210PHOSPHORUS 672 672 743ZINC 827 827 903BARIUM 0 0 1 Values Should Be* PROPERTIES SUS Viscosity @ 210°F 51.4 46-59 cSt Viscosity @ 100°C 7.69 6.0-10.2 Flashpoint in °F 410 >355 Fuel % <0.5 <2.0 Antifreeze % 0.0 0.0 Water % 0.0 <0.1 Insolubles % 0.1 <0.6 TBN 3.3 >1.0 TAN ISO Code * THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE 416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 www.blackstone-labs.com ©COPYRIGHT BLACKSTONE LABORATORIES 2015 LIABILITY LIMITED TO COST OF ANALYSIS We'll be debating transgender bathrooms when the Mullahs nuke us.
I had to do a double take when I saw this was a V10 with low miles. Forgot Ford was still using these in the Class Cs. Really wished Ford would make this engine available in the F250/350 models again.
Everything looks good but it's very hard to read the way you posted it. Next time try to make vertical column like the way the report is originally with some space between actually values and averages
I wish Ford would use it in the Raptor and Lightning banana
I agree and apologize. I had a hard time posting it. Didn't know that it wasn't available in the 350 anymore. Tow truck operators loved that engine.
Why? The current 6.2l v8 makes more power abs better mpgs. Maybe if they updated the valvetrain with current stuff.
