People overlook one important thing though. Cleaning ability of an oil contradicts its antiwear ability. This is because the antiwear additives and detergents fight for the same metal surfaces. The same detergents that clean the metal surfaces will also etch away the protective films of ZDDP and moly.
For that reason, an engine that is too clean may be a bad thing, as the cleaning ability vs. antiwear ability of an oil is always a compromise. You should start worrying if your engine looks too clean because it could be metal directly rubbing against metal with little antiwear-additive film present.
This is not to say that Mobil 1 is not carefully formulated not to etch away the ZDDP and moly films while it etches away the oil varnish, but just keep the compromise between the cleaning ability and antiwear ability of an oil in mind.
