Mobil 1 can clean all sludge within one OCI
One thing I have always known to be true about M1 is just how clean it keeps your internals. I don't doubt most stuff thesedays does, but perhaps M1 is the best choice for a cleanup oil for a newly bought used car or something.
So if M1 was a 9.7 on a scale of 1-10 for engine cleanliness..... Pennzoil ultra cleans 25% better, so that means PU is at staggering 12.425 - off the chart! Guess nothing does keep your engine closer to factory clean! lol
Mobil 1 -Synthetics leader for over 30 years.
All others bow down to Mobil 1!!!
LOL
I wish I could click on those pictures and see them full screen...
I also wish they were in focus... Oh well.
Disclaimer: I am running 0w-40 in the BMW and I like it.
In the bottom-end pics, is that circular item in the center of the engine the oil pickup? If so, I'd say that that is impressive. But I'd like to see more.
Thats what it looks like to me.
People overlook one important thing though. Cleaning ability of an oil contradicts its antiwear ability. This is because the antiwear additives and detergents fight for the same metal surfaces. The same detergents that clean the metal surfaces will also etch away the protective films of ZDDP and moly.
For that reason, an engine that is too clean may be a bad thing, as the cleaning ability vs. antiwear ability of an oil is always a compromise. You should start worrying if your engine looks too clean because it could be metal directly rubbing against metal with little antiwear-additive film present.
This is not to say that Mobil 1 is not carefully formulated not to etch away the ZDDP and moly films while it etches away the oil varnish, but just keep the compromise between the cleaning ability and antiwear ability of an oil in mind.
Yeah I'm very much aware of that. It's finding that balance and what you're going after that matters most.
In M1's case, it's always been extremely good at high temperature deposits and cold flow, but showed higher Fe wear maybe as a result. Today's synthetics have caught up to M1 performance though. PU especially. It's now a silly marketing game. Mobil 1's website and marketing have always been the most professional.
I`ve always wondered this as well. BuickGN (who used to post here) always said engines that used conventional oil showed less wear vs engines that used synthetic oil. He got his info by doing actual engine teardowns (and not via used oil analysis`s).
It's definitely possible. I wouldn't be surprised in some instances if that was the case.
Seems totally bogus. That looks more like cold dirty oil than sludge.
Whoever came up with this gimmick is about as convincing as the average congressperson.
Maybe maybe not.
Reference oil is a 9.50, M1 is a 9.70 and Ultra is 9.75.
That would also be 25% better than M1.
