Originally Posted By: ADFD1
I'm a tough sell for a $20+ 12 ounce engine cleaner, that might have to be used twice in certain applications doubling the cost. But I don't frown upon anyone who tries something and posts honest sincere testimony.
One of the funny things is that for $3 more than cost of one bottle of ARX you can get a complete Mobil 5 synthetic oil change package from Autozone. 5Qt of Mobil 1 and an Mobil 1 oil filter ($30).
When you factor in the cost of a complete ARX cycle, $40 for the ARX + say 2x$20 for the two conventional oil changes needed, it's much more expensive ($80 total) than just running Mobil 1 for two 3000mi oil changes ($60) + a quart of MMO ($4/quart) for 2x 1 pint applications.
With $20 to play with you could purchase all sorts of aftermarket additives to interfere with the Mobil 1's chemistry. For example, I like to add Lubro-moly MoS2 anti-friction ($7 at AAP), so as to clog the oil filter with colloidal MoS2 and then add 1 pint of MMO 500 miles before each oil change.
http://www.liqui-moly.com/liquimoly/produktdb.nsf/id/usa_2009.html
So ARX is expensive for what you get, and that would be the case even if it does work. If it doesn't work, then it is even more expensive than commonly thought.
