- Joined
- Sep 28, 2002
- Messages
- 39,793
Okay, we've seen M1 show slightly elevated Fe levels when other metals have been at par with other like products in like weights. We could reason that one oil may, more or less and indexed over an appropriate OCI/weight/etc., will show like numbers ..or at least a like grouping of numbers (higher or lower).
In the case of M1, however, we see typical elevated Fe levels. Now some have suggested that these elevated Fe levels are somehow part of the additive package. I've gone through the VOA library and found, without exception, that the entire M1/D1 lineup has 1-2ppm Fe in their virgin state. So where does it come from
This leads me to the question about the VOA/UOA process and perhaps how additives work once inside the engine. Can we assume that the XYZFTR process doesn't break down compounds into their sub components? Can we assume that some additive compounds are broken down leaving, in the case of M1, free Fe in the oil??
If this has been explained before, my apology. If you put Fe and M1 in the search feature you get about 300 hits ..and about 50 of them didn't yield anything about it.
