4wd
$50 site donor 2026
I think Mobil 1 Annual Protection was as well without the badges - what I ran was 60-70% PAO
There’s also a $15 rebate on that deal.I just did the AAP oil bundle with the Carquest EP filter and ESP 0W-30. The new Advance Clean is also eligible!
Those same people who will walk into a 7-11 and buy a 20 Oz $3 Coke?Who actually buys multiple single quarts at those prices when it is so much cheaper in the jug? In fact I never buy single quarts even though my Corvette has a 7 quart capacity
They would have had a much bigger marketing splash if they would just introduce Mobil 2.While it looks like a new formulation based on the VOA, you can tell who they're targeting based on the name of the product. Mobil 1......thousand.
i wonder if this is their response to Valvoline Restore and ProtectView attachment 310042
Just found ot in AAP here. Looking forward to read everyone's experience with it!
he's rolling in that Valvoline cash about nowNot real until there is a LSJR video.
now you can use it to heat your home tooSump full of advanced clean + Valvoline Restore and Protect + ec30 for a super cleaning. Just cut the filter open and it looks like this
My feeling is that this is their marketing department's response, rather than product development.i wonder if this is their response to Valvoline Restore and Protect
That depends on how well the oil can dissolve debris.My feeling is that this is their marketing department's response, rather than product development.
Because they go with "with a single oil change" cleaning argument, which is actually a worse thing than a 4 oil change argument.
And how much debris there is to dissolve.That depends on how well the oil can dissolve debris.
51 reactions, could be a record.
But where will it go afterward? Either clog the filter and then cause un filtered oil circulate, or have it move around in the oil, and i am not sure which one is worseThat depends on how well the oil can dissolve debris.
If the debris was truly dissolved, I wouldn’t expect it to clog the filter.But where will it go afterward? Either clog the filter and then cause un filtered oil circulate, or have it move around in the oil, and i am not sure which one is worse
Nice. Well, I will go for neither and stick to oils with HTHS levels of 3.5 and above and change every 5k miles.
Still, a good rival to Valvoline Restore and Protect.
I miss those days when manufacturers did share more specs about their oil. I wonder what HTHS does Valvoline Restore and Protect have. Probably only 0w40 would meet your expectation thoughNice. Well, I will go for neither and stick to oils with HTHS levels of 3.5 and above and change every 5k miles.
0W-20 is 2.65 and 5W-30 is 3.2 for HTHS.I miss those days when manufacturers did share more specs about their oil. I wonder what HTHS does Valvoline Restore and Protect have. Probably only 0w40 would meet your expectation though
