I ran Mobil 1 5w20 for the first time in this after using GTX 5w20 since it was new. I can't say it did a bad job, but not any better than the Castrol. Also the 100 cSt of 7.37 seems pretty low. It has M1 5w20 EP in it this time and I was planning on 9k if this one looked good. That seems reasonable but it's not as good as I was hoping.
Comments: Copper was the only element reading out of line with universal averages in the first report from your F150, and that dropped slightly this time. Most other metals increased slightly, but that's normal on a longer oil run, and we don't see evidence of any sort of problem developing. Universal averages are based on ~5,300 miles of oil use, so your wear looks pretty good in this sample. You switched to Mobil 1 from Castrol GTX, so the additives are a bit different, but this new oil seems to be working well. The TBN was still good at 3.2, so try for 9K miles next oil. Nice!
Code:
Oil M1 5w20 GTX 5w20
MI/HR on Oil 7,127 5,383
MI/HR on Unit 69,581 62,454
Sample Date 4/3/12 10/7/11
Make Up Oil 1 1 AVERAGES
ALUMINUM 5 4 3
CHROMIUM 2 1 1
IRON 17 7 16
COPPER 8 9 4
LEAD 0 1 1
TIN 0 0 1
MOLYBDENUM 78 6 63
NICKEL 1 1 1
MANGANESE 0 0 2
SILVER 0 0 0
TITANIUM 0 0 1
POTASSIUM 0 0 2
BORON 38 6 56
SILICON 12 11 14
SODIUM 119 294 30
CALCIUM 1206 1808 2229
MAGNESIUM 720 7 115
PHOSPHORUS 679 709 719
ZINC 833 834 858
BARIUM 0 0 1
PROPERTIES
SUS Viscosity @ 210°F 50.3 56.0 48-57
cSt Viscosity @ 100°C 7.37 9.07 6.7-9.7
Flashpoint in °F 390 395 >355
Fuel %
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.2 0.4
TBN 3.2 3.7
Code:
ALUMINUM 5 4 3
CHROMIUM 2 1 1
IRON 17 7 16
COPPER 8 9 4
LEAD 0 1 1
TIN 0 0 1
MOLYBDENUM 78 6 63
NICKEL 1 1 1
MANGANESE 0 0 2
SILVER 0 0 0
TITANIUM 0 0 1
POTASSIUM 0 0 2
BORON 38 6 56
SILICON 12 11 14
SODIUM 119 294 30
MAGNESIUM 720 7 115
ZINC 833 834 858
BARIUM 0 0 1
PROPERTIES
Fuel %
Water % 0.0 0.0 0.0
TBN 3.2 3.7
