No one really discussed whatt “track use” means. For me I think it it means full throttle, 6,000 rpm, driving with full boost from the super charger. Although the engine temp might stay at 210 F, the oil temps would go up because of the higher combustion temperatures. Like one poster said, you would probably burn through a quantity of xx-30 oil. In this case I guess I would side with the high vis guys and use a xx-40 oil.
However, there is no need to extrapolate that conclusion to your daily driver and say if 40 Is good for Vettes, I should use it in my Chevette.
