Car is driven for fuel economy, many short trips of 10-15 miles usually make weekend trips of about 100 miles round trip. Winter is finally over (we don't get very warm here until May) so the engine won't be seeing the cold startups until October. The oil is still in the engine (the sample was pulled through the dipstick) and I will report back at 14k.
A note on the makeup oil. Initially I added only about 3.25 quarts to get the oil to about halfway between the add and full marks on the dipstick. Later TeeDub pointed out that the length of an extended oci depends in part on how much oil is in the engine. For this reason I added oil to get the oil level closer to the full mark in mid- February. I had thought a half quart would bring it to full but realized that the low mark on the dipstick is 1.5 quarts below full (I had thought this was 1 quart). So the short story is I started about a half quart low, took out a half quart for 4 samples (4 oz each) which accounts for the 1 quart added so far. The engine has burned little to no oil over 12k.
Comments appreciated.
Dennis
Code:
Blackstone Labs Oil Analyses for 2004 Prius
All samples pulled through dipstick, oil has not been changed since
Sept 2006. Will continue to analyze every 2000 miles up to one year.
Approx 53.9 mpg over 12002 miles or 222.7 gallons 87 octane
oil filter Mobil 1, air filter is OEM
Oil Type Mobil 1 0W20 SM GF4
Oil placed in service 9/26/06 at 50455 miles
Sample Date 5/4 4/3 2/11 12/23 11/13 5/4
Year of Sample 2007 2007 2007 2006 2006 2007
Makeup oil(qt)* 0.25 0.625 0.125 0 0 * added since previous UOA
Miles on Engine 62457 60465 57983 55358 52834 Univ VOA
Miles on Oil 12002 10010 7528 4903 2379 6400 0
Aluminum 4 4 4 3 2 3 0
Chromium 0 0 0 0 0 0 0
Iron 12 9 8 5 1 8 1
Copper 1 1 1 1 0 1 0
Lead 0 0 0 0 0 0 0
Tin 1 1 0 0 0 0 0
Molybdenum 100 94 88 94 91 65 93
Nickel 0 0 0 0 0 0 0
Manganese 1 0 0 0 0 1 0
Silver 0 0 0 0 0 0 0
Titanium 0 0 0 0 0 0 0
Potassium 1 1 1 0 0 1 1
Boron 43 42 40 47 51 60 74
Silicon 13 11 11 12 12 14 3
Sodium 6 6 3 5 4 7 4
Calcium 2456 2234 2210 2273 2220 2341 2080
Magnesium 16 13 12 11 11 32 13
Phosphorus 668 636 599 631 613 628 770
Zinc 806 774 700 739 720 725 871
Barium 0 0 0 0 0 0 0
Viscos SUS210F 51.9 52 51.5 53.9 52.2 53-59 54
Flashpoint (F) 370 400 370 365 370 >355 440
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.3 0.3 0.2 0.4 0.2
TBN 3.4 4.4 4.6 2.9 8.6 9.9
TBN of 2.9 was probably in error, 4.6 result rechecked twice (4.5, 4.7)
1/8 quart (4 oz ) Mobil 1 0W20 added 1/11/2006
5/8 quart (20 oz) Mobil 1 0W20 added mid Feb 2007
1/4 quart (8 oz) Mobil 1 0w20 added 4/3/2007
Dennis
Code:
Iron 12 9 8 5 1 8 1
Lead 0 0 0 0 0 0 0
Tin 1 1 0 0 0 0 0
Fuel %
