I would like to begin extended drain OCI's after my second-owner VW (if they would even honor it now) warranty expires at 50k. The problem is, the new Mobil 1 extended drain oils are not available in either 5w40 or 0w40, which is what my VW recommends for my car.
I have listed my car's complete engine specs. & maintenance history below. Can you oil experts advise as to which of the new M1 oils, if any, you would use in this car, & the maximum drain interval that you think safe for this car. I'd like to go with the 15k oil......
Car: 2000 VW GTI 1.8L TURBO 4-cyl. ~ 150 HP ~ Engine is 100% stock. I am the second owner; I purchased in 11-03 w/15k miles.
Current vehicle mileage: 43k miles
Prior maintenace history: no records from previous owner; for all I know, it could have been running on factory oil fill @15k.
My maintenace intervals:
1. Dealer put in Castrol GTX 5w30 @15k - oil filter used ??? - I neved looked.
2. serviced at VW dealer @21,500 miles - oil used ??? + OEM VW oil filter
3. serviced at Wal-mart @28,300 miles - Super Tech 5w30 from bulk tank + Fram Extra guard oil filter
4. serviced at Wal-mart @33,100 miles - Super Tech 5w30 from bulk tank + Fram Extra guard oil filter
5. Came to my senses!!! DIY oil change @36k miles - Mobil 1 0w40 + OEM VW oil filter + installed new Fram air filter.
6. DIY oil change @41k miles - Mobil 1 0w40 + Mobil 1 #M1-205 oil filter
If none of the new M1 oils fit the bill for this car, how long do you guys think I could safely run the current M1 0w40....5k, 7.5k, 10k, assuming 95% highway driving @ 70-75 mph, 80 miles round trip per day.
Thanks in advance.
Thanks in advance.
