Has anybody used MMO in a similar fashion as Seafoam to clean the top end of an engine?
Originally Posted By: seafoam directions
To remove carbon and varnish deposits more quickly, Sea Foam can be induced directly into the combustion chamber via the following method. With the engine warmed up and running, SLOWLY POUR 1/3 to ½ can of Sea Foam down the carburetor throat or into any main manifold vacuum line that DISTRIBUTES EVENLY TO ALL CYLINDERS...
Once the product has been applied, turn off the engine and allow the Sea Foam to heat soak for a minimum of 10 minutes.
Has anybody tried this? Did you notice a difference?
