Originally Posted By: HerrStig
And how much more heat is produced at the same load but higher RPM? Very little.
Actually alot. RPM's = Heat. More cylinder firings in same amount of time. More heat is generated. If you want to test this thery, drive an air cooled bike in top gear at 50 MPH, then drop down a gear or two at same 50 MPH. You have same amount of cooling air going over cylinders, same load, now look at the temp guages and see how much hotter it runs.
(Yes, water cooled will do the same, just using air cooled because you can see it better)
