Originally Posted By: Vikas
The trouble with P0420/P0430 is that it is very difficult to attribute a single cause to it. In most cars, once the mileage has accumulated (i.e. 100K +/- miles), the 95% tripping point is now *very* close. A small change in *any* of the engine parameter can trip that code. Conversely, adding some PEA cleaner etc might get the code to trigger slowly. Unfortunately, without actually looking at the live data and comparing the front vs back O2 wave pattern during the deceleration, it is very difficult to claim that MMO causes P0420 or PEA fixes P0420.
Leaky, tell me about your experience with extinguishing P0430. Was stopping the MMO usage the *only* difference?
If it were that easy, I would be blaming Gumout Regan for turning on P0446 on my Camry and TC-W3 for P0401 on my Odyssey. Both the CELs tripped within 50-100 miles after adding the respective additives. But I know better
- Vikas
Ok, will try. Been using different cleaners for years like everyone else, never a problem. Varying doses, I never overdo anything. One day I put 1/2 pint of MMO in 18 gallon full tank and boom, a P0420 appeared 1/2 way through the tank. Normally a P0420/P0430 wavers in and out for a while. Not this one, the CEL was on hard. Was it the MMO or something else? I wasnt sure. To verify I took the manifold cat off, degreased it, sprayed off the media, put it back on. Light was off after a day. At the end of the next oil changed I added the same amount of MMO again to test. Towards the end of the tank the P0420 CEL was off again!
Coincidence? Sure, the cat was old, I burn oil, etc. But they don't set the CEL off. What I think is the combination of fouled media and MMO causes the problem, NOT MMO alone.
That was the best I could do to attribute the CEL to something. While the results can be disputed for the other variables given, the results cannot exclude MMO as a source of the problem. So..Unless your sure the cats clean, don't have any mechanical issues, dont use it in the gas.
Onto your comparisons with other fuel cleaners. I think it depends on ingredients. Sure, carbon is a threat, but its oil and lubricant that drowns the media, puts the cat furnace out losing its efficiency. So a fuel additive low in upper cylinder lube is a better option for a modern engine and catalyst IMO. I've brake boostered the same engine, same cat with techron concentrate, light didn't come on.
