quote:" Has anyone ever used MMO in their gas on a thumper? I read somewhere that a kawasaki rep recommended it for the kx250f because people were having problems with their valves breaking. I'm getting my new bike this week so I was wondering if I should try it. "
What year? If it is an '04, there is little to do to fix valve issues with that year. Kibblewhite makes a SS valve kit, seats, springs, and hardened buckets, but my experience shows that the cams wear quickly with the hardened buckets, so even if the valve issue itself is fixed, you are still in the top end for something. Regular maintenance of the sump screen is critical in any case, as the top end WILL starve for lube when it starts getting covered. Personally, I feel that oil choice is critical in KX's, as oils with a lot of solids tend to clog the screen quicker. I had no trouble with MX4T, but had screen issues with Motorex Synt. Could be my bad luck, YMMV.
Some of the valve issues were addressed in '05, with a seat change, and cooling issues are covered with larger rads. The trans got a different third gear, as the '04's had issues with trans lockups and shattered gears.
To answer directly, MMO is not going to help the valves in a KX, nor will leaded fuel. Leaded fuel MAY extend the life of the valves marginally, but evidence exists on both sides of the fence- some have gone a long time on leaded, others have failed early, just like on unleaded, and vice versa. The only thing that will fix the valve problems in a KX is to buy a YZ.
Checkout www.thumpertalk.com for a board as professional and informative about thumpers as BITOG is about oil.
