Originally Posted By: Capa
Your problem is that you keep in dealing with absolutes. While I may create a mix that is slightly inferior there is no doubt that I can create a mix that is slightly superior. What if my 5W-20 has sheared and I add a quart of 5W-30 to bring it back to an acceptable 20 weight level. Then, yes, I have created a superior oil given my specific situation. Pleas note that I am not saying that one should always mix a 20 weight with a 30 weight but there are scenarios where it MAY be beneficial. You mention specific testing and so I am really wondering how you feel about boutique oils that lack said certifications?
Unfortunately, since you screwed up the quotes, I'm unwilling to take the effort to dissect all of the points you made in response to mine. The bottom line is that you can claim that you've created a superior product, and trump up all the strawmen you want to support that premise, but until you have actual performance data, it is nothing more than a WAG. An educated WAG? Sure, I can cede that possibility, but it is not verified performance.
With respect to boutique lubricants I know that at least some of those manufacturers run their products through a myriad of OEM testing regiments and simply are unwilling to pay the price necessary for the approvals. That is, they validate the performance of the product by running the many tests that are available to formulators to meet a given performance level, they simply don't pay for the OEM approvals. So yes, to a degree you are dealing with a bit of an honour system, but there is no doubt that the performance of the blended lubricants is indeed verified, which makes it markedly different from just tossing some OTS oils together and assuming you've made a better product.
