Mixing motor oil
Arizona, USA
Is there a problem mixing different brands of motor oil in my car engine so long as the mixed brands are the same viscosity (5W30) and API service grade (SM) ?
Bill
2010 Subaru Forster
Bill
2010 Subaru Forster
No problem. You can even mix different viscosity grades if you want.
Go for it. In one of my atv's, i have a mix of M1 4T 10w-40 (synthetic), valvoline 4T 10w-40 conventional, and shell rotells T4 10w30 (HDEO). Runs great!
I'm looking at Mobil 1 15w50 for my Nissan 300ZX. Curious if I used 3qts 15w50 and topped it off with Mobil 1 Extended Performance 0w20.
Originally Posted By: Dumc87
I'm looking at Mobil 1 15w50 for my Nissan 300ZX. Curious if I used 3qts 15w50 and topped it off with Mobil 1 extended performance 0w20.
No such animal as 0W20 EP.
Would be:
14.95 cSt at 3/1 15W50/5W20EP
14.85 cSt at 3/1 15W50/0W20AFE
Basically is would be similar to a 40 Weight HDE0. Have you considered just buying a gallon of Shell Rotella T6 5W40 ($21) if you want a heavier 40 weight (compared to Mobil 1 0W40)?
Personally if you havnt tried it I think Mobil 1 0W40 would make an outstanding oil for that engine.
This is ForesterBill mixing:
Also,
-Dennis
Yep, I definitely got that mixed up lol Sorry
I'm actually using T6 5w40 right now; seems to be working great! The oil is already a bit dark, so I'm sure it's been working on cleaning things up over the last 5-600 miles or so. Way too short of an oil interval, but I am curious to get something a tad lighter since I don't have a track driven twin turbo.
Mobil 1 0w40 has been recommended actually. Right now I'm trying to figure out some oils that may work from Motul (either 0w30 X-lite or 5w30 X-max seem to be the choice so far)
I am going to install an aftermarket oil pressure gauge soon, hopefully this week, so I may get the 0w40 Mobil 1 since it's readily available at Wal Mart.
