Mixing Gear Oils
FL
I've heard that some mix GL-4 and GL-5 gear oils for shift feel. Are they chemically compatible or are there any issues I should know about?
I have a 2 quarts of Amsoil MTG and 2 quarts of Amsoil SVG which I may put in a Mazda 3 transmission (the owners manual says either gear oil spec is ok).
It may not be the best habit but if the two types are O.K. for the vehicle I wouldn't have a problem mixing. This would especially be true for me with gear oils. I do it with motor oil at times too.
I suppose if one doesn't know for sure then error on the side of caution which will cost me 10 dollars. Probabaly the wise choice.
GL4 for a transmission with Syncros, GL5 everywhere else. MT-90 is pretty close to being GL5 but it can't deal with Hypoid gears.
If in need of a stouter manual transmission oil, Redline's Lightweight Shockproof does GL5 while maintaining the proper friction numbers for good shifting. There is also Motul 300, it's a another very good oil.
