75w110 and call it a day
Just use the 75W-110. Engines are not that sensitive to viscosity, let alone differentials.I want to mix 75W-90 and 75W-110 from Amsoil. The point is that my rear differential actually requires Castrol BOT 720 with a viscosity of 18. W110 has a viscosity of 20, while 75W-90 is 16. As a result, when mixed, it should come out to exactly 18.
What do you think?
Only the European ones though, right? The ones you told us have “unique bearing tolerances”.Just use the 75W-110. Engines are not that sensitive to viscosity, let alone differentials.
Pray tell, where are getting your information so as to arrive at this conclusion?...Engines are not that sensitive to viscosity, let alone differentials.
Here, on this forum. Use the search button, you will find the same.Pray tell, where are getting your information so as to arrive at this conclusion?
I guess you'll have to explain sensitivity and unique bearing tolerances and what they signify.Here, on this forum. Use the search button, you will find the same.
Where did I use the words "sensitivity" and "bearing tolerances"?I guess you'll have to explain sensitivity and unique bearing tolerances and what they signify.
Engine sensitivity, in simple terms, refers to how an engine responds to changes in friction and lubrication between its moving parts. It's like how sensitive your skin might be to rough surfaces. Some engines are more "sensitive" than others to changes in oil quality, temperature, or wear patterns. This sensitivity determines how efficiently an engine runs, how it performs under different conditions, and ultimately how long it will last.The viscosity ratings might look similar to American oils, but European blends are specifically engineered for manufacturers' unique bearing tolerances and turbocharger requirements. It's less about superiority and more about different engineering philosophies meeting regional regulations.
Post #22 https://bobistheoilguy.com/forums/t...75w-90-and-75w-110.393095/page-2#post-7180719
In tribological terms, what is engine sensitivity and unique bearing tolerances?
Oh my. There is a lot of imagination going on in all of that.Engine sensitivity, in simple terms, refers to how an engine responds to changes in friction and lubrication between its moving parts. It's like how sensitive your skin might be to rough surfaces. Some engines are more "sensitive" than others to changes in oil quality, temperature, or wear patterns. This sensitivity determines how efficiently an engine runs, how it performs under different conditions, and ultimately how long it will last.
Bearing tolerances are essentially the allowable variations in the size and shape of engine bearings. These are the parts that allow smooth rotation between components. Imagine trying to slide a ring onto your finger - if it's too loose, it wobbles; if it's too tight, it won't fit or move properly. Similarly, bearings need to be manufactured within specific measurement ranges (tolerances) to function correctly. These tolerances are particularly important because even tiny variations can significantly affect how well an engine runs and how long it lasts. Different engine designs have unique tolerance requirements based on their specific operating conditions and performance needs.
Okay oil expert, what are your credentials? I'm a hobbyist that likes to read. You seem to know better, so, let's hear it. Make it easy to understand.Oh my. There is a lot of imagination going on in all of that.
You're always asking for credentials. Do you mean my education? I've stated that before on here, but not very often. I don't think that is relevant but if it is, then I have a BSME and a minor in Chemistry. I'm not an "oil expert" nor have I ever claimed to be one. I'm only responding to things people post and that I'm reading.Okay oil expert, what are your credentials? I'm a hobbyist that likes to read. You seem to know better, so, let's hear it. Make it easy to understand.
There is no such thing tribologically as engine sensitivity. A specific engine design may show, through testing, how it reacts to certain external factors. You're incorrectly using the word sensitive as if it had human attributes, a fallacy called "reification."Engine sensitivity, in simple terms, refers to how an engine responds to changes in friction and lubrication between its moving parts. It's like how sensitive your skin might be to rough surfaces. Some engines are more "sensitive" than others to changes in oil quality, temperature, or wear patterns. This sensitivity determines how efficiently an engine runs, how it performs under different conditions, and ultimately how long it will last.
You have a basic misunderstanding of the difference between Tolerances and Clearances, so here is a link to assist in understanding the difference:Bearing tolerances are essentially the allowable variations in the size and shape of engine bearings. These are the parts that allow smooth rotation between components. Imagine trying to slide a ring onto your finger - if it's too loose, it wobbles; if it's too tight, it won't fit or move properly. Similarly, bearings need to be manufactured within specific measurement ranges (tolerances) to function correctly. These tolerances are particularly important because even tiny variations can significantly affect how well an engine runs and how long it lasts. Different engine designs have unique tolerance requirements based on their specific operating conditions and performance needs.
You do realize that I repplied to a question I was asked about something I don't know much about, so I read, put time into it, and provided an explanation using simple terms.You're always asking for credentials. Do you mean my education? I've stated that before on here, but not very often. I don't think that is relevant but if it is, then I have a BSME and a minor in Chemistry. I'm not an "oil expert" nor have I ever claimed to be one. I'm only responding to things people post and that I'm reading.
But back to the post I called imagination. I said that because you're making up a bunch of stuff there. That whole paragraph on "engine sensitivity" is completely made up. Engines are not skin.
Bearing tolerances have nothing to do with this. Tolerances for bearings hasn't changed. Did you mean clearances? You tried to make this point earlier about how European engines require certain oils because of their "unique bearing tolerances". That's silly. They do not have unique bearing tolerances that result in needing a special oil. This is just pulled from thin air.
By the way, I'm not the only one questioning you about this. Ask the others for their credentials too please.
Engine metalurgy matters to oil formulation. That is why sometimes we have specific oils for specific engines. One of the many reasons I should say.There is no such thing tribologically as engine sensitivity. A specific engine design may show, through testing, how it reacts to certain external factors. You're incorrectly using the word sensitive as if it had human attributes, a fallacy called "reification."
Thank you for the link, I'll read it.You have a basic misunderstanding of the difference between Tolerances and Clearances, so here is a link to assist in understanding the difference:
https://www.epi-eng.com/mechanical_engineering_basics/clearance_and_tolerance.htm
I don't think that is a good idea since one would have to go through a list of all members to make that determination, and by what criteria?I think it would be useful to have tags or badges showing who's an expert and who's a hobbyist, novice, etc. Heck, I wouldn't mind being tagged as a novice or hobbyist, because that's essentially what I am.
