Mission failed, attempt to rethread spicket.
GON
$150 Site Donor 2025
White Sands, NM
Outdoor spicket had a anti siphon device attached. The anti siphon device leaked whenever the spicket was in use.
Took big tools to break the anti siphon device from the spicket. I later learned the anti siphon device was attached at the factory, and never meant to be removed.
The threads on the stripped. I tried a plastic hose connector as a retrofit, mission failed.Next I tried a like device in metal, failed . finally I tried a rethread spicket tool, mission failed.
I now have to cut a hole in the finished wall behind the spicket to gain access to the spicket to replace the spicket. I think I will just use a access panel to cover the hole I make in the interior wall
I've learned one thing about outdoor hose connections ( the hard way like you). Use anti-seize on any metal male to female thread ( anti-seize on the male side ), and you will never have a problem getting it apart. The minerals in the water act like liquid welding. You'll never get them apart again after a while. Plastic connections are never a problem, but they strip out.
For the future, they sell new ones at Lowe's. Remove the bottom half from the new one and put it on your old one. Leak fixed.
The connection was on so tight it collapsed the threads when separating the anti siphon device from the spicket. I needed huge tools to do the separation.
I speculate this was junk anti siphon device brand new, and was prone to leaking over time.
Figured out what happened.
The previous homeowner turned the anti siphon valve hold screw so tight it bent the spicket threads, this the leak. The previous homeowner or plumber that installed the anti siphon valve turned the lock screw so tight the lock screw broke at the entrance to the valve body.
Here is the anti siphon valve brand new. Will post the picture later, it is on a format BITOG doesn't accept.
I have never had any anti-siphon device on an outdoor spigot last more than a few years before leaking. I believe water gets trapped in the cavities and freezes during the winter, eventually rupturing the rubber anti-siphon "check valve" that works in reverse of an anti-drainback valve in an oil filter. I will always remove them when (or before) they fail since it is only a matter of time (unless you live in AZ or FLA).
  • Helpful
Reactions: GON
My faucet fell apart and wouldnt shut off..
luckily i can access the pex line feeding it in the basement ceiling.
used the sharkbite faucet.. 5min repair.
They have many styles.. one might work for you.
Good news, plumber installed the spicket directly to a brace inside the exterior wall, very easy to replace spicket, as long as a person can shut off the water
The plumber didn't install a shut off valve.
I opened the wall, allowing me to connect the dots. Face plate instead of repairing and painting the drywall.
The bad, Home Depot and Lowes only stock the cheapest Chinese spickets. I went to both. I will order quality spickets on Amazon, and will have to redo the job. I am working for now.
The leaking anti siphon spicket leaked so bad, that the wall of the home was getting damaged.
View attachment 292905View attachment 292906View attachment 292907View attachment 292908View attachment 292909View attachment 292910View attachment 292911
I installed some Taiwan beauties 26 years ago....no issues
Best of luck
Best of luck
These are not your father's Taiwanese plumbing parts of three decades ago. Rest assured, these are the lowest cost materials known to the plumbing world. I think I paid about $9.59 USD per spicket.. I imagine Lowes paid about .25 per spicket. That's how it works now adays.
