The car's a 1997 Subaru Impreza 2.2L. The idle is misfiring and very lumpy, but once I get on the gas the car drives fine without any misfiring CEL coming on. Also the ignition timing is at factory spec.
I used the ignition timing light and checked all four plug wires with the strobe light. Seems like #1 and #3 (fires together, waste spark system) has intermittent "blackouts" compared to #2 and #4. Could an ignition coil be almost dead and fires intermittently consistently or am I facing ECU troubles?
