It did on my xB
Meh power progressed to lean codes and stupid high fuel trims, progressed to hard starting/vapor lock, then eventually wouldn't run
If you're suspecting it's a fuel issue, make a thorough test of pressure, ability to hold pressure, and flow
I would've saved myself a lot of time
Had to learn somehow 🤷♂️
Edit: you lost me at the Dorman t brand fuel pump driver module
Have you checked powers and grounds to said FPDM?
FORScan is your friend when it comes to full data access and bi directional control
I purchased forscan lite for my phone. Fuel pressure is showing anywhere from 59-60psi but nothings coming out. Not getting any fuel trim data as it’s not starting at all. Basically useless for me right now. MAF was showing 2.84 g/s despite not even cranking key. My friend has an ‘11 F150 5.0 and I was comparing data with his. His MAF showed 0 g/s until the key is turned. So, logically I replaced the MAF sensor thinking it’s not reading correctly. No luck. His fuel pressure was also showing 59-60psi.
Pulled the fuse box to inspect wiring and install a factory TSB for fuel pump fuse relocator - all is good. Haven’t tested voltage running to the pump yet but I’ll have to drop the tank to get to that connector. I ended up bypassing the FPDM and still had no luck even seeing fuel pressure come out of the tank. Swapped both new dorman and old OEM FPDM with no difference
since it’s too cold to be doing anything outside I decided to tear apart my old fuel pump(also a Delphi unit) to see how it works. Submerged the pump in water. Turns out, when I send 12v power directly to the pump it whirrs but nothing comes out of the output hose on the pump. The pump currently in the truck is also a Delphi unit. Since it’s Christmas Eve I decided to run to Autozone to pick up a spare fuel pump so I have one on hand tomorrow incase I find out it’s a pump issue(it also is a Delphi, all they have in stock). I hope this $300 pump is good.
At this point I highly suspect the pump is dead(I’ll test voltage to the connector first). I purchased it off Rock Auto. Funny part is, they retail for about $180 on their site right now. I only paid $48 2 weeks ago and it was pretty late at night. Possibly system error? No clue. But the Delphi pump(same part #) I got from Autozone is fully wrapped up in the box. My pump from Rock Auto was not packaged the same way despite being the same part. I almost feel like the Rock Auto one is a fake Delphi or was at minimum defective, tested, and resold.
Regardless, when that rock auto pump originally went into the truck it held fuel pressure overnight. I had to drop the tank a second time to get the filler neck back on and when I popped the fuel line off it sprayed gas everywhere. It doesn’t do it anymore.
