avacado11
Thread starter
Genuine Ford or aftermarket fuel module?
Leaky injector, bad sensors, bad coil(s), or electrical glitch are worth troubleshooting. Get that fuel PSI prior to replacing pump. Otherwise, it becomes a shotgun repair.
Dorman aftermarket. I caught myself real quick. Already threw on a new EVAP purge valve($30) and a new battery($120). Purge valve was leaking slightly, battery wouldn’t hold 12v overnight so I guess it was money that had to be spent anyways.
After finding that leaving the key in the on position helped, and pulling the fuel line and putting the key on resulted in a drop of fuel coming out I had a feeling it is the fuel pump.
Anyways, I’ve got the tank strap bolts broken loose so all I need to do is drop the tank tomorrow and change it out. Not too hard, just have no motivation due to the cold weather. I will check the wiring above the tank while I’m at it.
