mini fridge not cooling?
I bought a mini fridge for the shop and I put a thermometer in it and it was only at 50 degrees. So I put the temp knob up to 6 and now its at like 43 degrees. It only goes to 7 so it got me thinking, are these mini fridges not like real fridges where they don't cool down to 36 degrees? The drinks felt plenty cold when it was at 50 degrees. I wonder if maybe the fridge thermometer I have isn't accurate. Or are these fridges not really meant for food, just drinks?
Originally Posted By: Reddy45
Does it use refrigerant or is it thermo-electric?
Yes, does it have a real compressor or a Peltier/TEC cooling module?
I've got a Danby that has refrigerant and a compressor 3.3cu/ft. It will get so cold it will rupture the sodas if you turn the knob past 75%.
If you have just moved it and it runs a compressor, let it settle for 20 min with no power before plugging it in and switching it on.
If you didn't do that, just switch it off for 20 minutes, then turn it on again. Sometimes it can help a lot.
It's a magic chef 3.5cuft unit. I've heard they don't cool as well when you don't have very much in it.
Is the compressor running all the time or cycling on and off? If it is running all the time it will not get colder turning the knob down. If it is cycling you need to find the proper thermostat setting.
Put your thermometer in ice water and confirm that it reads 32.
It takes a little longer since I assume the garage is also not air conditioned? which means it is probably close to or even at 100F in Houston TX.
I just read the manual online,it says it isn't for garage or outside use. Interesting....... everyone I see has mini fridges in their garage or outside by the pool.
I'd be content with 43 degrees on one of those....important thing is it's actually working and cooling. These are not typically the best on reliability. My neighbor bought one when his primary fridge wasn't handling things. I don't think he got more than 1-2 yrs out of the small unit.
My wife still has her Kenmore dorm fridge from when she was in college in the late 90's. It's set to 38F according to an old Delta 1 film developing thermometer. It is used inside and I do take it outside a couple times of year to defrost it.
You didn't specify but I bet it's thermoelectric.
These types of fridges can only go around 20-40*f below ambient.
They work fine indoors for wine and cigars but you need a refrigerant type model if you want to keep drinks cool outside.
I think the placement in the garage is causing the issue.
I have three of them:
1. A small 30 year old Sanyo cube fridge that will turn water bottles into ice slabs if not adjusted carefully.
2. A large Danby (about 4.3 CU Ft) that we use for a beverage fridge in the kitchen. We keep the temp in the middle of the thermostat and everything is plenty cold.
3. A slightly smaller GE that we keep in the basement. I keep it about 5 or 6 and it does keep stuff cold (although, not as cold as the 2 above,) Prior to this, I had a Magic Chef the same size which this one replaced (it had an unfortunate defrosting accident.) These fridges are such commodities that the GE was exactly the same as the Magic Chef, except it was black and had a GE badge on it. It was used in an office setting until I retired. Kept everything cold, although I could never crank it down and get a true "Ice-Cold," like the other two.
You can probably keep it in the garage, although you are going to have to keep it cranked and expect it to cycle. You can probably expect a shorter life cycle, although these things are so cheap that it is not a huge deal.
I've heard this before, but nobody has explained to me why.
I've still got a small dorm sized one kicking around from 1989. If it's not loaded with stuff to hold the cold, they don't seem to get very cold as said above. I thought they were all compressor-less fully electronic jobs today. I guess not!
It's got something to do with refrigerant and oil settling in the accumulator.
