Mini cooper dipstick. How to read?
I changed the oil in my 2008 Mini Cooper myself for the first time. It’s got the metal tipped dipstick. For anyone who knows Mini Coopers, how can read it with new clean oil? When the oil gets dark, it’s easy to read but with new clean oil, I just can’t see where the oil level is. The capacity is supposed to be 4.4 quarts. I’ve put in about 4 quarts from a 5 quart jug. Are there any tricks to see where the oil level is?
Easy wipe the dip stick dry then insert then remove a read...the part that is wet will be the oil...
The dipstick is like a coiled metal… the oil can be hard to read as it soaks into the coils.
What I do is have a clean paper towel - pull the dipstick, clean off the end, reinsert and then place it against the clean part of the towel. It will show you where the level is when it soaks onto the paper towel.
Thanks! I will try that. Yeah, it’s like a long, skinny spring. When the oil is dirty, it’s not too hard to read but you just can’t see where the oil is when it’s new. I’ve always had the dealer do oil changes because they always had deals but those days are over. This has always been a problem reading the stick but I trusted that they filled the oil with the correct amount. But doing it myself, I don’t want to overfill it.
  • Like
Reactions: hrv
I wonder if there's an aftermarket or another oem option that fits and is easier to read?
(Peugeot designed) N12/N14/N16/N18 Mini engines came with the worst
dipstick ever. Aftermarket options? Yes, they exist, but just marginally better.
The cause/root is the S shaped dipstick tube. A Cravenspeed dipstick can't
change that bloody tube.
No news! No need to reinvent the wheel:
I use to just remove the dipstick in the evening to let all oil residue in the dipstick tube drain into the pan over night and put it back in next morning to read it. This is the only way to get a proper read on a R56 Mini. Make sure you have proper lighting, as pour light can make reading the dipstick a pain. Some people add MoS2 to darken the oil, which probably doesn't hurt.
Or play a light source over the tip in a manner which reflects the light.....much as you'd do if sighting down the length of a car looking for bad body work.
There's a company that makes dye for petroleum products called Rekhaoil. Wonder if it might be easier to add a drop or two of dye into the crankcase so it shows up easier when the oil is new
The problem is, the coil dipstick is shiny so it’s hard to differentiate shiny oil from shiny spring.
That might work. Once the oil darkens, it’s easier to read.
I have a visibility issue with the 5W-20 synthetic oil when I try to read the dipstick on my Generac 20kw standby.
I have read about fixes including scuffing the shiny surface with file/paper, making small notches in the dipstick edges, checking level in bright light, and adding a dye.
As vpr5703 indicates there is a company REKHOIL that makes an oil soluble dye for oil...$8.00 incl S/H!
https://www.ebay.com/itm/255647544443?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3D3310f806420747b78674191fcd57d1e9%26pid%3D101506%26rk%3D1%26rkt%3D10%26sd%3D262871741734%26itm%3D255647544443%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecall&_trksid=p4481478.c101506.m1851
I ordered the minimum 0.25 oz which REKHOIL rep indicates that quantity will dye 37 GALLONS of oil.
When queried about quantity to dye 2 quarts in my generator they indicated 1 SMALL DROP to attain bright red.
