Mildew on caulk in shower
Near the beach in Delaware
My shower has some horizontal caulk around a seat in a walk in shower. It's got black mildew. My professional cleaner guy said he has scrubbed at it and cannot get it clean. Remove and re-caulk was his suggestion.
So two questions:
1) is there anything I can try. I assume my professional cleaner has already tried several products.
2) if I remove and re-caulk what can I do to prevent it in the future.
I am thinking it being horizontal caulk is part of the problem.
As a last ditch effort before doing a cut and recaulk, you could try some concentrated liquid pool chlorine, (commonly known as, "shock"), applied directly on the affected area, and allow it to sit for several hours. If that doesn't do the trick, nothing will.
Just be sure to have the bathroom window(s) open, and the exhaust fan running. That stuff is nasty if inhaled. Also, keep the bathroom door closed to prevent it from permeating the rest of the house.
You can clean it, it will come back.
Remove all old caulk and soap.. Clean really well. Bleach. Rinse. Soak with isopropyl. Dry with fans for days. Clean with hexane to remove silicone residue. Dry some more.
Install the best caulk, see link above.
I believe once mildew and mold starts it’s a lost cause. I’d take out the existing caulk and reapply.
I recently bought one of these and it works slick for removal and dressing caulk.
Just my $0.02
So two questions:
Nothing will remove the mildew except to remove the stained caulk. Many "bathroom" cauks are mildew resistant for many years.. Providing better ventillation will help in keeping mildew from forming in the future.
Absolute best at getting mold and mildew from under caulk. It is a gel, so it'll hold and stay on vertical caulk lines and horizontal surfaces. Apply and let it sit for a few hours, then rinse.
This stuff was amazing. Squirted the stuff on and waited a few hours and rinsed it off. Mildew was gone, caulk was white.
So two questions:
Bleach
Hydrogen Peroxide solutions have been great for my recent home rejuvenation projects.
50/50 vinegar and water with a razor blade works great for built up soap scum
Your caulk/mildew problem… I had the same and frankly wasted way too much time and effort on it. In the end (and what I should have done from the start; just cut it out with a razor blade and recaulk with a good silicone type)
Glad it worked for you. I first heard about it on Ask This Old House and now always keep a bottle with the rest of my bathroom cleaning supplies now.
Awesome. You caught it in time.
We have miles of grout lines in our master shower. It’s nice and big but more grout lines.
We use soft scrub w/bleach- it’s the only thing that works. Mainly just keep up and makes the job way easier than we first moved in. Previous clowns did nothing. Hard water. 3 or 4 kinds of growth etc. Took razor blades and citric acid etc
I used to sell this. Needs 48 hours to cure, but works very well. Better than silicone.
