Microgard MGL10290 C&P
MicroGard Selects made in Vietnam are not "Wix made" - ie, made by Mann+Hummel. The subject filter in post 1 wasn't made by M+H in Vietnam. O'Reilly doesn't use Wix numbers for the MicroGard Select line. The ones made in India very well could be M+H based.
Premium Guard has all of these brands made in the Vietnam factory - ie, AFI = Advanced Filtration Inc.
Oreilly does use Wix numbers for the Select and standard. Same like Napa did maybe still does. You didn’t read what I said. The house brand Microgard, would they be buying from different companies for each filter number? Notice PG and Microgard Select are separate customers in your picture. So not PG “made”, but made for Oreillys.
Any private label filter customer can request any part number convention from any other filter maker they so choose. It does not imply the part number convention they use from whatever maker is made by that maker.
This is what you said in post 9:
"So here is the hornets nest, I think they are all made by Wix under Mann Hummel. Oreilly uses the Wix numbers and I can’t see that they buy one filter from premium guard and another from Wix. Likely it’s all from Wix including the Select. Premium Guard isn’t a manufacturer in Vietnam but maybe I am wrong."
And I responded that the MicroGard Select is not a Wix/M+H made filter like you tried to "surmised". As others already said, the MircoGard Select is just the name that O'Reilly wanted on the filter for their house brand. PG can still be in the picture and all those other brands shown are still under the PG umbrella. You really think every company that brands their filters as shown in that photo are in direct contact with VAFI? ... doubt that. That chart shows only a connection between PG and the VAFI factory. Look at the top of the picture, and read the text.
The "Premium Guard" brand is also made in the same factory as all those other brands I posted in post 19 because PG sells them under their own brand name. All the other brands shown are "made for" brands. Just like M+H and Fram made filters for others with different brand names on them.
“O'Reilly doesn't use Wix numbers for the MicroGard Select line.” It’s ok if you are wrong. I wasn’t saying I was right about Wix supplying Oreilly. It was conjecture based on observations. No use turning it into something it is not.
^^^ As already pointed out, many filter makers use similar filter model numbers, but that doesn't mean they are then made by the original company that started using those numbers. Many filter makers use some Fram filter numbers too, but they aren't connected to Fram in any way.
The bottom line is you think Wix/M+H makes any filter that uses their filter numbers, which is really doing down the wrong rabbit hole.
You said, “O'Reilly doesn't use Wix numbers for the MicroGard Select line.”
But they do, It’s ok if you are wrong.
“you think Wix/M+H makes any filter that uses their filter numbers” No, wrong. I Don’t think it.
It does look like some MicroGard Selects do use some Wix numbers.
You really still think that Wix/M+H makes MicroGard Select filters (made in Vietnam) for O'Reilly's because they may use some of the Wix filter numbers? That was your original theory. If so, why isn't there anything on the MicroGard Select boxes and/or label that references M+H like any other M+H "made" filter. O'Reilly's contracted through PG, not Wix/M+H, to make the MicroGard Select.
Looks like someone is just trying to stir the pot again….
Look who really stirs the pot here, not me. The only reason I come here right now is to see the Fram Ultra with the nylon core cut open so I don’t have to spend $9 for nothing.waiting for wcw to get one. Otherwise I have to stop wasting the time.
One thing to work on, don’t tell people what they think.
I actually took a few minutes to check a couple select numbers before I responded. Wix. You didn’t get away with saying I was wrong about it. Telling others they are wrong, but never saying you are wrong, work on that too. I work on things, everyone comes here with best effort. If it becomes a game of one up over another it devolves into nothing.
I saw what looks like Wix filters made in India at Oreilly, but other numbers were Vietnam. Since stores usually wouldn’t be buying each number from different vendors, I made a question. Like I said, maybe it’s a hornets nest. Yeah it’s a hornets nest, and a few lead hornets.
What got this discussion rolling in the first place was you thinking just because a filter uses a Wix filter number must mean it's also made by Wix - see post 9 which is what you "think": "So here is the hornets nest, I think they are all made by Wix under Mann Hummel. Oreilly uses the Wix numbers and I can’t see that they buy one filter from premium guard and another from Wix. Likely it’s all from Wix including the Select. Premium Guard isn’t a manufacturer in Vietnam but maybe I am wrong."
So yeah, you were wrong about that, but right about the Wix filter numbers being used. Wix/M+H has zero connection to the MicroGard Selects from everything I've researched, and the info I posted showing what filter brands are made under the PG umbrella in post 19 shows that. None of those brands are associated with Wix/M+H either, they are all under the PG umbrella. As already mentioned, the lower tier MicroGard is a M+H filter, but the MicroGard Select is a Premium Guard filter. In this case, just because a filter uses a Wix number doesn't mean it's made by Wix/M+H.
Clearly meant to stir the pot. He seems to go out of his way to post on PG related threads.
It should be ok to make observations and deduce.
Don’t tell people what they think. When I said I think… I usually would have written a maybe, but it’s implied. In my thoughts it was implied. Example, I think it will rain today. Versus, It will rain today. In other words “I think” is always opinion. We are allowed to have opinions.
Back to the topic and your bullet points, the standard Microgard is made in India, Vietnam, and I think used to be made in Mexico or USA. Which leads right back to why I was thinking Wix may supply them all. It’s not likely Oreilly is going to different sources for each part number, and India stands out as different.
You are on a forum where correct details matter. If you cannot handle a course correction and learn from it, then you are going to be filling out hurt feelings reports quite a bit.
Trust me, I have been mistaken and corrected more than once around here and probably will a few more times in the future.
What people write is what they think. You're the one "thinking" MicroGard Selects are made by Wix/M+H ... you wrote it. Pretty much every comment made by anyone is their implied opinion, regardless if it's correct or not. The truth of someone's opinion is shown with substantiated proof. Thinking that MicroGard Select filters are made by Wix/M+H because they use Wix filter numbers is not any proof that Wix/M+H makes them. No more than thinking that SuperTech filters are made by Fram because they use Fram filter numbers on many of the SuperTechs.
Until you can prove that Wix is actually involved in the production of MicroGard Selects, then my opinion based on available information shown in post 19 & 32 is that Wix/M+H has nothing to do with the MicroGard Select filter line. I'd also venture to say the regular MicroGards made in Vietnam are also under the PG umbrella. The regular ones made in India, Mexico or the US are/were most likely the Wix/M+H versions.
Here's what looks like the Wix/M+H version of the regular MicroGard MGL10290 back in mid 2022 when this one was made, per date code on the dome .
Just some info I found digging around the 'net. Shows the big connection between Premium Guard Inc (PGI) and the in-house MicroGard branded products at O'Reilly Auto Parts.
"January 29, 2025 - PGI received the highly coveted Supplier of the Year award, a key achievement that recognizes the company’s outstanding performance in delivering high-quality products, operational reliability, and unwavering support to O'Reilly Auto Parts and its customers. The award reflects PGI’s ability to consistently meet O'Reilly’s standards, provide seamless supply chain execution, and contribute to the success of O'Reilly’s operations and growth strategy."
https://www.premiumguard.com/pgi-ea...rts-including-prestigious-top-supplier-award/
