Originally Posted By: 2010_FX4
Originally Posted By: CapriRacer
But the key point is that you don't have a center differential, you have a transfer case.
Correct; I guess I have never seen a 4WD set up with a center differential, but then again I have not messed around with any 4x4s other than GM or Ford in the past few years. Is this a Toyota, Honda, Nissan thing?
A quick look shows NP242 "Selec-Trac" was some sort of Jeep transfer case, with 2H, 4H with 48/52 torque distribution, 4H locked, N and 4L locked. I saw an N249 which appears to be similar but with a viscous coupling instead of mechanical.
A friend of mine, years ago with a Bronco (second gen? the full sized one, long before EFI) had a full time 4WD setup. Looking that up, it might have been a NP203 (NP205 is part time). Here is an exploded view of an NP203:
http://www.offroaders.com/tech/Diagrams/NP203diagram.jpg
you can see the diff in the bottom center of the pic.
http://www.offroaders.com/tech/Diagrams/np203.htm
Quote:
The New Process 203 was used in GM, Ford, and Dodge through the 70's behind auto and manual transmissions. They were originally a full time 4wd 'case, meaning all 4 tires receive power at all times. This was made possible through use of a differential in the back of the 203 that let the front and rear drive shafts turn at different speeds as just as a diff in an axle lets each axle shaft turn at a different speed. For off road use, the 203 had a "lock" position in which the differential was locked making the front and rear outputs spin at the same speed. Shift positions are: High, Lo, High Lock, Low Lock and Neutral.
Here is an NP205:
http://www.offroaders.com/tech/Diagrams/np205.htm
No diff seen.
I'm pretty sure the Land Cruiser has used lockable diffs for years, otherwise, Toyota has kept with part time 4WD systems on anything that has a low range. The first gen RAV4, if in stick, was full time 4WD with an open diff that you could lock if you absolutely had to. They quickly dropped that in favor of viscous couplings instead. From what I understand today, the RAV4 actually only has two diffs, front and rear; but the rear uses clutches etc to allow variable coupling (the "transfer case" that you'd expect is just a set of gears in the transaxle, no diff, so constant speed for the driveshafts not constant torque--oddly enough, front and rear diffs use different gear ratios, as does the Ridgeline).
